  1. #5
    I was thinking these
    https://www.ebay.co.uk/itm/15mm-line...cAAOSwNWxaJP-~
    I could butt 2 together to get lengths I desire so £240 would support 2 3m lengths.
    The choices so far
    1. 2* 2525 ballscrew 2.7m with decent quality BK/BF fittings ~£1000
    2. 2* 3232 2.5m with fittings ~£1500
    3. 2* 2010 with fittings 2.7m length fully supported with the clone rail and 2 carriages per ballnut leaving me 4 spare carriages in total, I could then use 6 carriages to support the Z axis which has the same rail on it given me 50% more strength without affecting travel. ~£600
    I would think the 2 biggest factors in critical speed are how straight is the ballscrew and how good are the bearings in the BK/BF fittings, I might even play with type C mounting method but I believe this needs super precision although doubling your criticial speeds.
    Resolution is not so relevant as I'll use servos, not sure how powerful but was told 400w should be ok I think £2k will buy the servos and the mesa controller so I can use linuxcnc.
    I really want to direct drive with oldham coupling but it can be belt driven I suppose, the most important things are large travel, good accuracy and good speed.
  1. Replies: 0
    Last Post: 29-11-2016, 02:16 PM
  2. NEW MEMBER: Hi,Friend,I'm a B2C seller from China for ballscrew,linear guide,linear shaft etc.
    By yvesleeok in forum New Member Introductions
    Last Post: 10-08-2013, 11:15 AM
  3. ballnut housing and floating end ballscrew assembly
    By dsc in forum Lead Screws, Nuts & Supports
    Last Post: 12-07-2013, 08:22 AM
  4. Linear rail and ballscrew dimensioning for R/C router
    By CarlNicholasCarlsson in forum Linear & Rotary Motion
    Last Post: 24-03-2013, 06:52 PM
  5. Using SBR12 as ballscrew end support
    By Lovre in forum Lead Screws, Nuts & Supports
    Last Post: 13-12-2012, 08:52 PM
