Thread: CNC Router Aluminium surfacing
I think there are many methods, tools and theories of what is "best". Personally I am using simple four flute, 6mm diameter bits at 18-22krpm and that works fine for me. The surface is very smooth and shiny. I can't use larger ones because I have ER11 spindle. I would not dare using any fly cutters with these high speed spindles.
08-05-2018 #2
08-05-2018 #3
Close your eyes and feel the surface with the tip of your finger or the nail of your index finger. If you can feel the pattern then it is machine related and not good. Otherwise it is normal. There is always a visible pattern unless you polish the surface. Of course, you must use sharp tools.
09-05-2018 #4
Don't use coated endmills on aluminium. You will tend to get build up on the tip and poor finish. I find these work well. Also make sure you have a good grade of aluminium for machining - it makes a world of difference.
Russell
09-05-2018 #5
tooling leaving ridges means your spindle is out of tram in one or more axis (ie it is not perfectly perpendicular to the X/Y axis)
The smaller the bit, the less obvious this will be so one solution is to use smaller bits and smaller step overs but you will never get a really smooth surface unless you spend some time shimming your spindle into tram (or if your machine has adjustable tram then even better than shimming of course).
As mentioned above you will always have visible swirls/marks but if the surface feels ridged then look to tramming as your solution. With good tram, it should be relatively easy to polish away the tooling marks with some light sanding.Last edited by Zeeflyboy; 09-05-2018 at 03:39 PM.
BUILD LOG: Not the avarage aluminium router
By Sven in forum DIY Router Build LogsReplies: 8Last Post: 25-01-2017, 02:42 PM -
BUILD LOG: Aluminium FEA optimalized CNC router
By PotatoMill in forum DIY Router Build LogsReplies: 65Last Post: 28-07-2016, 08:25 AM -
Surfacing bit and t-slot bit
By eurikain in forum Workshop & EquipmentReplies: 11Last Post: 25-04-2016, 01:58 PM -
Surfacing Spoiler board
By CommanderKenyon in forum Machine DiscussionReplies: 7Last Post: 08-10-2015, 01:47 PM -
Spoilboard Surfacing - What tool(s) do you use?
By Mad Professor in forum Tool & Tooling TechnologyReplies: 6Last Post: 12-01-2013, 11:55 AM
