    Lives in Marple Stockport, United Kingdom. Last Activity: 22 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by ravihotwok View Post
    Cheers lads,
    yeah one step at a time andy mate
    cheers clive, I will probably set the machine home to the highest z point and x,y to be the centre of the bed as the parts im going to be making will mostly be fixed down to the tooling plate around the edges, so makes sense to keep the spindle away from part? Or maybe at the rear of the bed in the middle
    I think you are misunderstanding the difference between machine zero and work zero. You are correct to have the Z home to the top then all z gcode will be negative. its nice to home the machine so that X & Y movements to the work position are +ve.
    The work zero G54 is generally where you set it in CAD. So after you have homed you then move the machine to the Zero in CAD then touch off at that point. Work zero G54 can be anywhere on the table and in a different place every time if you want. The Home position is always in the same place.
  1. 3020T Capabilities
    By TT901 in forum Chinese Machines
    Last Post: 03-03-2017, 04:20 PM
  2. Chineese 6040 problems
    By Kendrick57 in forum Gantry/Router Machines & Building
    Last Post: 18-10-2015, 10:52 PM
  3. Ballscrew for 3020T Y Axis
    By richie00boy in forum Lead Screws, Nuts & Supports
    Last Post: 02-08-2013, 02:47 PM
  4. A viable mini-ish-mill build, or a hiding to nothing..?
    By Wal in forum Milling Machines, Builds & Conversions
    Last Post: 02-07-2013, 07:33 PM
  5. Replies: 18
    Last Post: 04-06-2009, 03:44 PM
