  1. #2
    Quote Originally Posted by Nealieboyee View Post
    Hello boys and girls,
    After a long long time of promising myself to build a machine, I'm finally going to do it. I hope to mill/cut plastic, wood, and hopefully some aluminium up to 6mm thick. Accuracy I'm aiming for is around 0.1mm if possible.
    Here is my machine plan. I would love some constructive criticism.
    Specs:
    Y-axis supports are 40x80 extrusion.
    X-axis gantry is 80x120mm heavy duty extrusion.
    Gantry side plates are 10mm aluminium plate.
    machine base is a tooling plate of 10mm aluminium. It has a few holes here and there, which I've modelled in sketchup, so excuse those please.
    Final working area is around 440x280mm, but if I can find a bigger base plate, that would be great.
    Motors: I'm not sure, but probably around Nema 23 size, perhaps 4Nm?
    Rails will be 20mm Hiwin, or Chinese, depending on price.
    Ballscrews will likely be 1605.
    Would someone be so kind as to critique my build please? :) Note that I haven't included the ballscrews for the x and z axes yet. Still working on positioning those. Ideas?
Name:	x axis side.PNG
    Thanks all :)
    Hi Nealieboyee,
    Good to see you going for a build.
    Like me i think you will like building a machine your self.
    Things i see that a lot of people do different.
    Move the horizontal rails on gantry to top and bottom of the profile instead of front side.
    The downside is that it will raise the height of the machine some 5cm
    Move the vertical rails to the moving part of the Zaxis.
    These changes will be more rigid and the spindle moves closer to the gantry
    Please take a look at the routercnc mk3 and the Davek build.
    Would end plates connecting the base plate to the Xaxis, to get the Xaxis profiles a little more rigid, be a good idea?
    https://r.tapatalk.com/shareLink?url...2&share_type=t
    Grtz Bert.
  1. Aluminium Extrusion Router Build
    By NFryer in forum Gantry/Router Machines & Building
    Last Post: 03-07-2019, 07:59 PM
  2. Homemade CNC with Scrap + Chinese parts || Objective: Milling Aluminium ||
    By laranjas3 in forum Gantry/Router Machines & Building
    Last Post: 16-11-2017, 10:18 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  5. BUILD LOG: Work scrap bin router build
    By Vic66 in forum DIY Router Build Logs
    Last Post: 17-01-2010, 08:51 PM
