  1. #3
    Quote Originally Posted by driftspin View Post
    Hi Nealieboyee,
    Good to see you going for a build.
    Like me i think you will like building a machine your self.
    Things i see that a lot of people do different.
    Move the horizontal rails on gantry to top and bottom of the profile instead of front side.
    The downside is that it will raise the height of the machine some 5cm
    Move the vertical rails to the moving part of the Zaxis.
    These changes will be more rigid and the spindle moves closer to the gantry
    Please take a look at the routercnc mk3 and the Davek build.
    Would end plates connecting the base plate to the Xaxis, to get the Xaxis profiles a little more rigid, be a good idea?
    https://r.tapatalk.com/shareLink?url...2&share_type=t
    Grtz Bert.
    Thank you for your kind words :) I've moved the x axis linear rails to the top of the gantry as suggested. I've also rotated the base plate to give me more usable space in the x direction. If I can find a bigger base plate I may use that, or even welding a steel frame....We'll see soon.
    I've also added bracing from the y axis rails to the base plate. Do you think it would really help on the x axis too? Those braces also serve as the new plates for the bearing supports for the ballscrews.
    As for the z axis, I've moved the linear rails to the moving part of the axis and added side supports to give a bit more strength.
    Anything else that jumps out at you?
Name:	x axis changes.PNG
Name:	new z axis.PNG
Name:	x axis side.PNG
Name:	x axis braces.PNG
  1. Aluminium Extrusion Router Build
    By NFryer in forum Gantry/Router Machines & Building
    Last Post: 03-07-2019, 07:59 PM
  2. Homemade CNC with Scrap + Chinese parts || Objective: Milling Aluminium ||
    By laranjas3 in forum Gantry/Router Machines & Building
    Last Post: 16-11-2017, 10:18 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  5. BUILD LOG: Work scrap bin router build
    By Vic66 in forum DIY Router Build Logs
    Last Post: 17-01-2010, 08:51 PM
