Page 6 of 27 FirstFirst ... 4567816 ... LastLast
  1. #51
    Hi again.
    I.ve build the metal box and reorganized everything, and wired the new Bob. It seems the motor problem has gone, but will post a video soon and let you be the judge of that.
    Now, I.ve wired the Bob like in the photo attached, and I.m not getting any response from the input pins, from none. P10 to 15 are not seen in automated setup in mach 3.
    I should know the answer from the first picture from post 49, but the truth is that I don.t. :(
    What am I missing?
  2. #52
    If you are using the BoB in the picture, you will need the 12-24v input to work the LEDs in the output opto-isolators. It looks like you have a fault there. Also check that the GND connections are all together, except for the PC ground.
  3. #53
    the USB cable powers the two 74HC245 octal buffer IC's that connects the printer port outputs to your stepper drivers
    the 12 to 24v supply is required to power the five input opto-isolators
    & the PWM to 10V analogue converter that's controlled by pin 1
Name:	ebay CNC BOB.jpg
    when a switch grounds an input current flows through the opto-isolators LED so the NPN photo transistor is turned ON
    so the corresponding printer port input is grounded
    when the switch is tripped and opens
    the printer port pin goes high
    (set pin as active high in mach3)
Name:	ebay CNC BOB inputs.jpg
    John
  4. #54
    It has the 12 v input, a light is on on the bob at the end of the input pins. It makes a subtle high pitch noise when I connect any of the input pins to the ground pin, but it does not register it in mach 3.
    All grounds are together, but now I.m testing it with a single wire.
    Pc gnd is not connected to anything.
    The only difference with this bob is that it has a P14, to which all I ran all ENBL- from the drivers.
  5. #55
    does it still make a noise if you remover the jumper to disable the relay ?
    (I can't think of anything other than the relay that could make a noise)
    having a quick look at the data sheet for the LM317 regulator
    the 12 to 24V DC supply needs to be a minimum of 13.5V
    the supply goes via a diode that drops about 0.6V and the LM317 regulator should have an input that's at least 3V more than the 10V output
    is the 12V supply regulated ? or is it unregulated and is more than 12V if lightly loaded
    for your initial tests you can disconnect the connection to the stepper driver enable
    John
    PS
    a simple input tester I used to test a similar BOB without using a PC (or motion controller)
Name:	simple TX14175 BOB input tester.jpg
  6. The Following User Says Thank You to john swift For This Useful Post:
  7. #56
    Quote Originally Posted by Radu_Andrei View Post
    So you are using a USB cable from the PC?
  8. The Following User Says Thank You to cropwell For This Useful Post:
  9. #57
    the supply is a 12v transformer, which used to power up some car led.s strips. the multimeter reads 12.1 v. it is the one i use for the enclosure fans.
    as i fiddled with the wires, somehow it works now. probably a bad connection from the 12v supply. so Thank you!
    I looked a bit online, and the eccomerce webs in my country have plenty of 12v, but no 24 supply. Surely there might be some specialized shops somewhere.
    It works like this now. Do I ask for trouble if I don.t use a higher supply, 13.5v and above?
    Now on the other side of the bob, for spindle control via mach 3, from what I understand, the gnd pin goes to ACM, the 0-10v to V1, 1st relay pin (5th in order) to DCM, and 2nd relay pin to FOR.
    Is this correct?
  10. #58
    great to see you have it working even if your not 100% sure which connection you re-made during your investigation
    your connection to the VFD looks correct
    in practice using the 12V supply probably will work
    while the LM317's data sheet gives the minimum supply voltage as V out +3V this will be the worse case accounting for the production spread in the IC's parameters
    even if the supply is too low for the regulator to regulate the output as intended
    the fact you have a regulated 12V supply
    the voltage is likely to be near to 10V and not change too much and
    cause the calibration of analogue control voltage to the VFD to vary
    John
  11. The Following User Says Thank You to john swift For This Useful Post:
  12. #59
    I have another identical supply, so wiring it in series might give me 24v, or 20 due to what you said. I might have a spare laptop charger somewhere, which is 17 or 19v.
    If it is a requirement, I.ll do it.
    Thanks again for the detailed answer. :)
  13. #60
    Leave it alone at 12v - if it ain't broke, don't fix it. If you get 0 - 10v on the analogue output, you'll be fine.
  14. The Following User Says Thank You to cropwell For This Useful Post:
  1. Need a bit of help with servo settings/setup
    By alboy in forum General Discussion
    Last Post: 07-06-2018, 11:04 AM
  2. PWM Settings
    By Gunar in forum General Electronics
    Last Post: 16-02-2017, 12:33 PM
  3. Mach 3 default settings,
    By chris w in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2016, 01:54 PM
  4. Home Switches & Slave Axis in Mach 3
    By Tenson in forum Artsoft Mach (3 & 4)
    Last Post: 03-03-2014, 11:43 PM
  5. Help with settings!
