Page 7 of 27 FirstFirst ... 5678917 ... LastLast
  1. #61
    Ok. Thank you. And yes, the 5v usb cable is run from the pc. I have a phone charger available as well. It reads 4.74v at pc5v and pcgnd.
    Does it matter?
  2. #62
    phone chargers are not regulated very well
    so you will be better off either using the PC's USB port or using a regulated 5V power supply to power the 5V side of the breakout board
    John
  3. #63
    Quote Originally Posted by john swift View Post
    PS
    a simple input tester I used to test a similar BOB without using a PC (or motion controller)
    Attachment 24652
    I made Click image for larger version.
ID:	24654a pass-thru tester years ago when I was trying to work out what was happening with a printer/plotter I had. Exactly the same as that but with lower value resistors but each LED was powered by the printer or PC.
  4. #64
    John
    I use exactly that BoB with a 12/5v dual power supply from a defunct external hard drive. It works fine !
  5. #65
    Lives in Marple Stockport, United Kingdom. Last Activity: 20 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by Radu_Andrei View Post
    It has the 12 v input, a light is on on the bob at the end of the input pins. It makes a subtle high pitch noise when I connect any of the input pins to the ground pin, but it does not register it in mach 3.
    All grounds are together, but now I.m testing it with a single wire.
    Pc gnd is not connected to anything.
    The only difference with this bob is that it has a P14, to which all I ran all ENBL- from the drivers.
    What voltage do you have between an input pin and ground with out any switch connected?
  6. #66
    Hi.
    Sorry for the late reply, the internet was out for a while.
    Nice tester. It seems you guys are doing this electronics thing for quite some time. That.s why you.re all so smart. I suspected at first, that you.ve made a pact or something, like Faust, that you knew the answer to every problem I came up with. :P
    Regarding the question, if I remeber right, as I measured a lot of connections today, I don.t think it was any voltage between the input pins and ground, but I might be wrong. I.ll check tomorrow, if it helps.
    It seems ok so far how the project is going. I just finished a few hours ago to install the touch plate, added some script in mach 3, and it seems to work ok but a bit slow. I.ll change some numbers in there and should be fine.
    Next week I.ll set the soft limits, reconnect the x and y motors to the ballscrews, and run some tests. I don.t know, what test I need to check if I get steps missed, but at least I have a plan. :)
    Then add a flat wood surface and make it straight, mill it I guess, then add a sacrifice board on top of it, then learn some cam software, and also buy some ebay projects with sculptures and stuff, to have a go at cutting.
    I don.t know if all this ideas are good either, but thanks to you guys, I kinda feel confident it will all work just fine.
    There.s still quite some work to do, and I.m aware I.ll keep bothering you for some time, but still... A BIG THANK YOU to you all. :)
    You mean a lot for people without technical backgrounds. A couple decades ago, people were struggling to find info like this, and most of the time they could not.
    I have more gratitude to express, but I.m starting to sound creepy, so I.ll shut up.
  7. #67
    Regarding the question, if I remember right, as I measured a lot of connections today, I don.t think it was any voltage between the input pins and ground, but I might be wrong. I.ll check tomorrow, if it helps.
    If you have connected 12-24 v to the centre two terminal on the bob you should have about 7-12v on the input pins.
    if you have not got any volts on the inputs pins then you might have burnt the pcb track out on the board. I have seen this in the past.
    So just get one thing at a time working. Those bobs although cheap I find to be quite good.
  8. #68
    Hi.
    I just measured it, with and without the limits connected, and I get 0v between GND and all pins except P13, at this one I get 26v. P13 happens to be the probe, but I disconected the cable, and same reading.
    I don.t know how I could have burned anything, as I just run the usb cable from the pc, and the 12v supply.
    Yet the limits, estop and probe work fine. No more false signals. :)
  9. #69
    P.S. although the vfd is not connected just yet, on the bob I get 2 light on all the time, the 5v and 12-24v leds, and sometimes the relay led. It does not stay lit all the time. I don.t know if that.s bad or not, I just thought I should mention it.
  10. #70
    Does this mean that all is working OK?
    I am not sure why you have 26v on P13 !!
  1. Need a bit of help with servo settings/setup
    By alboy in forum General Discussion
    Last Post: 07-06-2018, 11:04 AM
  2. PWM Settings
    By Gunar in forum General Electronics
    Last Post: 16-02-2017, 12:33 PM
  3. Mach 3 default settings,
    By chris w in forum Artsoft Mach (3 & 4)
    Last Post: 08-01-2016, 01:54 PM
  4. Home Switches & Slave Axis in Mach 3
    By Tenson in forum Artsoft Mach (3 & 4)
    Last Post: 03-03-2014, 11:43 PM
  5. Help with settings!
