Page 6 of 8 FirstFirst ... 45678 LastLast
  1. #51
    I'm new to the forum. I very much like the look of this design and would like to have a crack at building it. What is the protocol for asking for plans or preferably CAD files ?
  2. #52
    Lives in Marple Stockport, United Kingdom. Last Activity: 23 Hours Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 3,348. Received thanks 620 times, giving thanks to others 90 times. Made a monetary donation to the upkeep of the community. Is a beta tester for Machinists Network features.
    Quote Originally Posted by cweeks View Post
    It looks like you have been a member for 9-10 years. It is best to start your own thread and ask the questions there.
  3. #53
    Hi everyone, I've got a couple of small updates on the build. Firstly I have made a couple of mounts for the inductive limit sensors on the x axis. I was originally going to mount them under the gantry carriage plate between the ballscrew and the carriages, but I realised that there was no way I could adjust them in that position so I had to move them to the outer edge of the plate. On the top of the plate I fastened a 4 way connector to take the 2 signals back across the gantry and bring power to them via a 4 way CY cable.
  4. #54
    Had you thought about mounting them so that they can slide past the target rather than into it? You can also get away with one limit sensor and a fixed target at each end.
  5. The Following 2 Users Say Thank You to Clive S For This Useful Post:
  6. #55
    Hi Clive, I'm probably missing something very simple, but I just can't visualise how you could only use one sensor to limit travel at either end of the x axis. I didn't mention this explicitly but I'm not having separate limit and home sensors, so I assume that's not possible with one sensor?
  7. #56
    Quote Originally Posted by NFryer View Post
    Ok imagine if you rotate the sensor by 90' and put a target at each end so that the sensor slide over it to trigger.
    the target would not be a the complete end but a small distance from it to enable the gantry to travel to the end before it trips. This is done at both ends.
    I believe Mach can use the sensor to home (then offset the home say 1mm) once homed Mach would then set it to be a limit switch. This way you would only need three sensors with three inputs. (not sure if you have a slaved axis ie two motors)
    If you have two motors to slave you would need two home switches one for each side.
  8. #57
    Hi Clive, once you mentioned rotating the sensor by 90' I understood what you meant, it'a a nice simple way of using one sensor. Unfortunately I've already done the X axis sensors, so can't change them, but it's something to remember if I change the design once built or build another machine.
  9. #58
    I've made a start on building the main frame for the router, and have made a couple of braces to fit between the middle pair of legs. A while back I built an angle cutting sled for my circular saw table which I used to cut the angles on the end of the aluminium extrusions. I also made a couple of simple plates to bolt the braces to the legs.
  10. #59
    Very sexy! :D
    Keep up the awesome work!
  11. #60
    Nice,like a tank!
  1. BUILD LOG: New Build, Aluminium Frame Router/Mill
    By Davek0974 in forum DIY Router Build Logs
    Last Post: 31-08-2016, 05:28 PM
  2. BUILD LOG: DIY Build of Aluminium CNC Wood Router without Workshop & Tools
    By WandrinAndy in forum DIY Router Build Logs
    Last Post: 05-11-2012, 06:22 PM
  3. FOR SALE: Aluminium Extrusion
    By vigen20 in forum Items For Sale
    Last Post: 24-07-2012, 11:01 PM
  4. BUILD LOG: Aluminium Extrusion CNC Router Build
    By joshendy in forum DIY Router Build Logs
    Last Post: 10-04-2012, 08:26 PM
  5. Aluminium Extrusion suppliers?
    By m_c in forum General Discussion
    Last Post: 12-04-2011, 01:23 AM
