    Is there a tool to help remove stuck morse tapers from the tail stock?
    Sent from my SM-N910F using Tapatalk
    Morse taper drift?, or if (like my ML7) you don't have a slot for the drift, I normally get a piece of bar through the rear bore of the tail stock butt up against the backside of the tool and tap it gently.
    No slot for a drif. Here is my tail stock
    Maybe some sort of wedge?
    Lives in East Lothian, United Kingdom. Last Activity: 1 Day Ago Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,992. Received thanks 376 times, giving thanks to others 9 times.
    I'm going to assume you've fitted some kind of short MT adapter that means when you wind the tailstock all the way in, the tailstock screw is not hitting the adapter and extracting it?
    In which case, suitable wedge, but you'll probably have to make/bodge something suitable. Cheap hammer/fork type ball joint extractors would also work if you find one the right size.
    No but it use to extract it. Maybe i can find a wedge that will do the job
    Quote Originally Posted by dfox1787 View Post
    It's not a hollow ended MT (aka threaded for use with a drawbar), which has been plugged, and the plug has screwed in a bit?
    If you are lucky - a tap on the chuck towards the headstock, with a soft face hammer may dislodge it. Otherwise if you can wind the quill out (after taking out the pin) you may be able to get a drift into the quill to dislodge the bugger.
    What lathe is it btw?
    Got there - Hobbymat MD65
    I've got the same lathe. I normally just wind it back with the hand feed and it pushes the chuck/taper out. If it's stuck really tight a bit of heat from a heat gun on the quill should expand it enough to release the tapered bit.
    Waldo
    Quote Originally Posted by the great waldo View Post
    Waldo
    Normally it does do that but recently if i wind it back it jams and doesnt push the morse taper out. I have had the tailstock apart and cant find any issues with it.
    Put an old drill bit in the drill chuck or old piece of bar stock. Slide the tail stock down to the main chuck and grab the bar in the jaws. In the gap in between gently tap with a nylon hammer on the front face of the tail stock.
    Once out check the end of the taper. Something is amiss as per earlier posters as the auto release is not working. Don’t reinsert until you have figured it out!
  1. Replies: 0
    Last Post: 01-07-2018, 07:38 AM
  2. Laptop stuck in BOotmgr missing
    By dazza in forum Laptops & Tablets
    Last Post: 28-02-2016, 07:08 PM
  3. feedrate stuck on low
    By routercnc in forum Machine Discussion
    Last Post: 24-04-2014, 10:24 PM
  4. Morse taper drills
    By John S in forum Marketplace Discussion
    Last Post: 08-05-2013, 07:00 PM
  5. 250mW LASER stuck on
    By korky in forum General Electronics
    Last Post: 12-07-2009, 10:47 PM
