Thread: X drifting right
Check your stepper to shaft coupling isn't slipping, and that the end float control bearing isn't moving, the best way is disassembly and reassembly as "Looking OK" has often proven misleading to others in the past
The Following User Says Thank You to magicniner For This Useful Post:
04-11-2018 #2
04-11-2018 #3
Serious professional builds usually have intermittent oil feed to the nut, this not only lubricates but keeps the screw and nut clean as the oil carries away any dirt.
04-11-2018 #4
