27-11-2018 #2
I'd have bought the 30LV if I'd known about this. At least I'd have got the 180mm travel I needed straight out of the box! (states 220mm max).
Once I start converting the 25 I'll set the table 20mm further back from where it is now and later on fit a 25mm head spacer.
That should be enough to achieve what I need.
Kind of annoyed.
I'm actually considering putting the motor and control box from the 25 onto the X2 while I'm messing with this. I get 160mm on the X2 with the changes I made.Last edited by dazp1976; 27-11-2018 at 12:46 AM.
27-11-2018 #3
you guys seen this: http://www.mycncuk.com/threads/12274...e-for-December
https://emvioeng.com
27-11-2018 #4
I suspect it will be exactly the same as my 25LV (identical spec) with Y travel limitations when the chip guard bellows are in place. Saw a post on CNC zone mentioning this the other day regarding a similar machine.
My advice would be: If you want a machine about this size with 180mm Y travel then the AMAT30LV is in stock atm.
Might not be for long though.
I'm unfortunately committed to my 25 now :(Last edited by dazp1976; 27-11-2018 at 01:49 PM.
27-11-2018 #5
What about this machine ? These better than the warco wm18 or AMAT30 ?
http://www.toolco.co.uk/products/vm3...ling-machine-1
27-11-2018 #6
The Following User Says Thank You to dazp1976 For This Useful Post:
17-12-2018 #7
Either the guy from toolco uk ltd is having the best holiday ever, or he has closed down or worse !!
I have been trying to contact them for past 2 months... just get voicemail saying he is away on holiday... however all emails checked... but not as sent a few.
I even contacted there ebay store... nothing.
CONVERSION: Warco WM18 Mill Stepper motor advice
By Gotty101 in forum Conversion Build LogsReplies: 7Last Post: 18-08-2018, 05:06 PM -
NEW MEMBER: Big hello from a total novice
By Edendale in forum New Member IntroductionsReplies: 1Last Post: 29-01-2018, 11:03 PM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
Total novice seeks advice on stepper motor drivers
By R.Andersen in forum Motor Drivers & ControllersReplies: 1Last Post: 25-01-2012, 11:34 AM -
Total novice and lost
By sfallan in forum Machine DiscussionReplies: 48Last Post: 10-09-2010, 10:35 AM
