@Hulksmash
I am just stripping down a 32B from toolco for CNC conversion. I visited Warco and checked out the other machines from Chester et al., but the Toolco (Weiss Machines) one was the best. The base castings are thicker with better geometry. The motor is more powerful with belt drive. I had to put up with the MT3 version but ordered a spindle from Michael Weiss, the machine manufacturer.
I found Toolco not easy to deal with, but it was worth it for the quality of the machine.
The only snag I can find is the top spindle speed which is something over 2000 rpm. Options for me are to change the pulley ratio or fit a high speed spindle in parallel on the head. Ways and general machine tolerances are extremely good. I can pm you Michael Weiss's email address if you think it will help.
Best Regards
picclock
18-12-2018 #2
Many thanks picclock,
That would be brilliant please if you could pm his email address.
Its between a 32B toolco machine or an Amadeal AMAT30 - I would want an R8 spindle too
Is the owner of toolco still alive ???? I cn never get hold of him. Would Michael Weiss sell direct ?
Yes I will probably add a spindle in parallel re spindle speed, would be good to know someone else was doing it.
regards
Mike
CONVERSION: Warco WM18 Mill Stepper motor advice
By Gotty101 in forum Conversion Build LogsReplies: 7Last Post: 18-08-2018, 05:06 PM -
NEW MEMBER: Big hello from a total novice
By Edendale in forum New Member IntroductionsReplies: 1Last Post: 29-01-2018, 11:03 PM -
NEW MEMBER: Heres me - a Total Novice
By CrazeUK in forum New Member IntroductionsReplies: 1Last Post: 14-03-2017, 03:47 AM -
Total novice seeks advice on stepper motor drivers
By R.Andersen in forum Motor Drivers & ControllersReplies: 1Last Post: 25-01-2012, 11:34 AM -
Total novice and lost
By sfallan in forum Machine DiscussionReplies: 48Last Post: 10-09-2010, 10:35 AM
