I am not sure if we are talking about different things.
I only operate the VFD with its own terminal. To be honest, I am a complete rookie with CNC and this is my first experience. I am pretty happy that everything works so far :), but having this feature would be the last step I wanted to go. If this is not working like I want regarding pump I can anytime let the pump switch on with the +24V Signal and DCM. The only drawback is then that the pump is running also when the spindle is not turning.
I believe you mean I could control it seperately from the VFD which is of course also somehow doable, but I am yet not that advanced so far. To me it would be sufficient just to operate this from the VFD.
10-05-2019 #2
Not difficult to do.
You could run a relay from your controller, activated on M8 (flood) or M7 (mist) G Code, that then enables the Coolant pump but then runs through another relay which is triggered by the Spindle Run command (For your spindle). I do the same for my CNC Lathe but dont care about spindle status.
Get yourself some 24V relays and drive the logic from your controller. What control option are you using?Last edited by Chaz; 10-05-2019 at 01:41 PM.
10-05-2019 #3
10-05-2019 #4
Ok, so can you have an option where, in your code, you enable a G Code and then enable an output signal? I used Marlin and RAMPS for my 3D printers, so it should be possible.
The same way a heatbed is activated (Relays on the board) you can do here. Enable a relay, switch an external relay that has logic. Ill draw a circuit diagram if it helps ... ?
10-05-2019 #5
Yes sure, this might be an option too. How to do it on a Ramps I am aware.
As I also dont see getting these UPF DCM DRV Ports running like I want, I will rethink this. Thank you for now.Last edited by chefffe; 10-05-2019 at 02:45 PM.
10-05-2019 #6
It should be as simple as this. Your spindle already has some logic to start stop. Tap into that, use a Normally Open switch (add a new relay if needed) to then feed a Normally Open switch triggered by Ramp's output for M8 G Code which then goes to your Coolant Pumps FWD connection. I've Grounded the common side but you need to work out what your VFD wants here.
10-05-2019 #7
Thanks for your drawing!
What connectors?
By Neale in forum General ElectronicsReplies: 4Last Post: 07-07-2015, 12:21 PM -
switching from steppers to servos - STEP / DIR control
By dsc in forum Stepper & Servo MotorsReplies: 6Last Post: 18-06-2014, 12:41 PM -
Driver switching OFF
By manofgresley in forum Artsoft Mach (3 & 4)Replies: 13Last Post: 06-06-2014, 04:57 PM -
FOR SALE: 24v 20 amp ABB switching power supply £90
By gavztheouch in forum Items For SaleReplies: 0Last Post: 07-02-2014, 07:42 PM -
Home switching
By Vard in forum General ElectronicsReplies: 6Last Post: 14-03-2012, 08:32 PM
