Page 2 of 2 FirstFirst 12
    Hi Eddy
    Thanks once again, I consider that a fortunate escape for me, they get a bit precious over their bits of wood
    I bet one of them will want a flat one anyway
    John
    I have been CNC cutting the slots, allows cutting on the radius and also somebody wanted blind slots, a bit cross your fingers with .5 mm cutters in hard wood
    Quote Originally Posted by johnsattuk View Post
    So what have you been using so far for the open slots ?
  5. #15
    Ive been using 0.5 mm slot drills, I generate the code using Fretboard.exe which is in imperial, so generate the code and scale it in Discriminator to suit the Estlcam controller.
  6. #16
    Cut a test one in a bit of pine,
ID:	25864   Click image for larger version.
ID:	25865   Click image for larger version.
  7. #17
    Looks okay, did you check both ends with radius gauges ?
    I'm not a fan of marker dots these days, I just use side dots and one at the 12th fret as a logo.
    What's the difference between a scalloped board and just using tall frets ? of course with the cnc it's no more difficult to make.
    Also don't be worried about asking me to process more dxf files, if it's to do with guitars I'm on board.
  8. The Following User Says Thank You to EddyCurrent For This Useful Post:
  9. #18
    Never had any experience with guitar making until now, have got dragged into it and actually finding it very interesting
    The guitar lads soon get out their guages etc whenever I cut something for them. as a non player I also wondered about tall frets.
    Thanks for the offer of help with files, I may well be asked for something different.
  10. #19
    [QUOTE=EddyCurrent;109021]Looks okay, did you check both ends with radius gauges ? [QUOTE]
    Man with guages says "perfect"
  11. The Following User Says Thank You to johnsattuk For This Useful Post:
  1. Converting .eps file for cam use
    By Leadhead in forum General Computing
    Last Post: 30-06-2017, 08:38 PM
  2. .GD4 file extension ?
    By greenz123 in forum CAD & CAM Software
    Last Post: 30-06-2015, 12:44 PM
  3. how do you convert a .png to a .tap file?
    By valeria caltabiano in forum General Computing
    Last Post: 16-02-2015, 01:25 PM
  4. File upload problems - attachments file extension support !
    By Swarfing in forum General Discussion
    Last Post: 08-03-2013, 02:37 PM
