It would help with the lateral rigidity, but it wouldn't be as good as a single thicker plate, as the flexing stiffness (in the flat direction) of a plate increases as something like the 3rd power of the thickness. The thing is that stacked flat plates can slide over each other therefore don't increase the stiffness so much. One thing that might work is if you glued the 2mm plates together with high strength epoxy, this would likely also help with damping a bit, but is obviously a bit of a faff to do
29-08-2019 #2
MicroRouter Spindle upgrade - advice and help required
By ngwagwa in forum Spindles & Drive MotorsReplies: 16Last Post: 26-05-2019, 02:52 PM -
Rigidity of aluminium profiles and rectangular tube sections....
By Voicecoil in forum Gantry/Router Machines & BuildingReplies: 6Last Post: 14-10-2018, 01:51 PM -
profile rail and purchase advice
By johngoodrich in forum Marketplace DiscussionReplies: 2Last Post: 17-09-2016, 07:53 PM -
Low profile, compact work-holding solutions. Advice sought.
By Wal in forum Tool & Tooling TechnologyReplies: 23Last Post: 26-08-2016, 10:45 PM -
advice on upgrade to 5 axis control
By alanb in forum General ElectronicsReplies: 17Last Post: 27-07-2012, 06:29 AM
