Just a quick update...i decided to change pd070 to input voltage 0-5v and it now works at full speed so I need to figure out why the AXBB is still only outputting the 5v even with the jumper removed or just stick with the 5v control. I'm assuming people use the 10v so it's more immune to noise?
Sent from my SM-G920F using Tapatalk
14-09-2019 #2
15-09-2019 #3
Charlie some of the huanyang VFD's have a jumper to change between 0-5v and 0-10v as well as being able to use the PD70 setting.
AXBB charge pump fault
By CharlieRam in forum CNCdrive (UC100, UC300ETH)Replies: 78Last Post: 18-07-2021, 08:31 PM -
CNCDrive AXBB super deal?
By driftspin in forum CNCdrive (UC100, UC300ETH)Replies: 18Last Post: 16-03-2019, 10:10 PM -
got 2 outputs from controller, need to connect 3 leds to them, any solution?
By Noplace in forum CS-Lab (CSMIO)Replies: 5Last Post: 04-02-2016, 08:51 PM -
Advice needed for controller box layout
By Bustercnc in forum General ElectronicsReplies: 23Last Post: 18-01-2016, 01:16 PM -
Help needed Dahlgren System 4824 And a DSC controller, what software will run it???
By fraserguitars in forum Machine DiscussionReplies: 0Last Post: 13-12-2015, 08:22 PM
