Linear rails and carriages will work - but you know that.
You're adding a lot of unnecessary height to the cross/top slides and the resultant increase in height of the spindle above the bed. I'm probably talking out of my arse here but the force on a cutter in the top slide lathe are a lot more predictable than a mill - typically with just about a single vector - are there no more appropriate systems than square rail for this application? That said, if you have the rail already....
If you want to cut tapers, and reduce your overall height - look at existing taper attachments for lathes (you need to be able to decouple the cross slide from the screw). You can lose the compound with this.
My main agreement with Pippen though is the amount of back-drive. Even on my somewhat light-weight ML7 you need a carriage lock to avoid back-drive on the original acme thread (I've yet to assess this on a ball/belt/stepper combo). My main, main issue though is bed length. If you know that this is sufficient for your need then go for it, but I can't help but think that you're going to be limited to something not much more that 100mm Z travel once you've finished.
EDIT: Cold light of day: back-drive - not with the spilt nut engaged (hence acme thread) - my bad, disregard - I had to lock the carriage to avoid back-drive against the rack-and-pinion of the carriage position wheel.Last edited by Doddy; 22-11-2019 at 08:46 AM.
22-11-2019 #2
All valid points. As you said, I already have the carriages and rail. I do have some acme thread I pulled out of a reclining couch a while ago. I can try to make some nuts for it. Either that or I can lock the ballscrew somehow to prevent backdrive.
I'll definitely lengthen the bed. I will lower the cross-slide and do away with tapers then. Perhaps design it to take a quick change tool holder.
This is just experimentation for me. I've always wanted a lathe and also to try my hand at epoxy granite. So why not. Not needing anything massive though.
BUILD LOG: Epoxy granite vertical mill build log
By Nick in forum DIY Mill Build LogsReplies: 60Last Post: 08-06-2020, 06:30 AM -
Large Format Epoxy Granite Gantry CNC - Looking For Feedback
By Max Maker in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 23-08-2019, 04:57 PM -
SOLD: Hobbymat MD65 mini lathe and BF65 mini mill
By Boyan Silyavski in forum Items For SaleReplies: 3Last Post: 03-11-2018, 12:45 PM -
Epoxy granite or mineral casting
By mike mcdermid in forum Gantry/Router Machines & BuildingReplies: 46Last Post: 20-02-2014, 06:21 PM -
Epoxy Granite Molds?
By gavztheouch in forum Moulding MachinesReplies: 8Last Post: 18-02-2014, 07:28 PM
