  1. I had an thought it could be this although x and y steppers are identical but x seems to be the one losing itself ever so slightly. Out of interest how do you change the steps? is it the motor tuning in mach3?
    Quote Originally Posted by divertom80 View Post
    Yes, it's in Motor tuning. Make sure you click the Axis selection on right before making any changes and save when finished.
    However, if the settings are identical it could be the Step pulse rising edge for the X-axis drive is on the wrong side. If the Step pulse is firing wrong you will lose 1 step with every direction change.
    The way to test for this is to write some G-code which makes lots of A to B moves and back to A. 200 or 300 short moves will do it IE:
    G0 x10
    x2
    x10
    etc, etc just copy paste 2 lines above finishing with.
    x0
    m30
    Then Zero Axis and make a Mark, set the code running and when it's finished it should return back to Zero and the mark. If it doesn't return to the mark your Step pulse needs changing.
    To do this go into Motor Outputs and change the Active Hi/Lo for the Step pulse.
    Only do this if it doesn't return to mark.
    Check all axis this way if unsure.
    GND's Avatar
    Lives in Cambridge, United Kingdom. Last Activity: 16-07-2024 Has been a member for 9-10 years. Has a total post count of 85. Received thanks 3 times, giving thanks to others 11 times.
    Also worth checking the squareness of your X & Y axes to one another. I had similar problems with my home built machine, and after much checking and testing, it turned out to be down to a v small error in the angle between the axes. Quite tricky to measure, and even harder to fix! But one to consider if the motor settings prove to be OK!
    Graeme
    Kitwn's Avatar
    Lives in Don, Tasmania, Australia. Last Activity: 3 Weeks Ago Has been a member for 7-8 years. Has a total post count of 985. Received thanks 118 times, giving thanks to others 52 times.
    Quote Originally Posted by GND View Post
    One of the advantages of a twin-motor long axis is the ability to square up the gantry during homing.
  1. New build (my first) can't draw circles.
    By mcyoung in forum Gantry/Router Machines & Building
    Last Post: 29-06-2015, 11:22 AM
  2. Replies: 8
    Last Post: 01-02-2014, 09:33 AM
  3. Sometimes Engineer's Squares aren't
    By routercnc in forum Tool & Tooling Technology
    Last Post: 25-07-2010, 09:59 PM
  4. Getting dizzy cutting circles!
    By fasteddy in forum Programmers Corner
    Last Post: 16-05-2010, 07:46 AM
