20-01-2020 #221
Hi Clive,
All I can tell you is throughout a season the total kwh used by the heat pump is is about the same or less than the 1hp water pump that is switched on for exactly the same time, I have clamp on current monitors on both going to the main energy logger in the house. The heat pump pulls about 2.9kw max and will bring 60m^3 of water from 18 to 28 degrees in a couple of days. Costs about £1k in electricity to run both per season. I have no experience of them in houses although a friend who has also just rebuilt his house is now relying solely on an air sourced heat pump for house heating with hot water boosted with immersion and tells me he is saving a fortune, but he wasn't on mains gas rather oil delivered by tanker which is expensive.
What maybe of interest is I had a 10kw pump heating a much smaller 10m^3 above ground pool, this was the older generation pump without the inverter and therefore constant compressor speed / current draw. The electricity cost of running this unit was the same per season as the new pool system, therefore it must have been much less efficient.Last edited by devmonkey; 20-01-2020 at 10:23 AM.
20-01-2020 #222
Clive
I looked into heat pumps several year ago, obviously ground source is the most efficient but due to my building plot this is not an option, max for air source is in the region of COP 5
https://www.viessmann.co.uk/products...s/vitocal-300a
Regards
Mike
20-01-2020 #223
OK.I think I have hijacked this thread and taken it off topic sorry. But thanks for the feed back.
20-01-2020 #224
As I said, the limiting factor on air-sourced reverse-cycle air con for heating is when the outside temperature is so low that the external heat exchanger freezes. In the UK I would expect you'd need some additional heating system for the coldest parts of the year (September to May in Cumbria if I remember correctly). In Perth (The Australian one rather than the original) we had a few occasions when the heat exchanger froze but but not many. A well insulated house obviously makes a big difference. It's been a while, but I think that unit used 4kW of electricity for the equivalent of 14kW of heating.
20-01-2020 #225
I have realised something about these sensors. They are colour sensors, and the colour detection is done by layering a grid of colour alternating RGB filters over the individual pixels which are all identical photodiodes (i.e. the pixel is monochrome) in what is called a Bayer pattern. These are laid out to match the human eye's response to colour, with 50% of the pixels green and 25% red and 25% blue. See https://en.wikipedia.org/wiki/Bayer_filter
This isn't ideal as I'm using a red laser. This means only 25% of the pixels are useful and the sensor will be interpolating the values between 'red' pixels.
Anyway someone pointed me towards some super crazy people in astrophotography who 'de-bayer' their very expensive DSLR sensors with a toothpick so the sensor becomes monochrome at its native resolution, effectively scratching off this colour filer layer to expose the raw sensor.
https://stargazerslounge.com/topic/1...-bayer-matrix/
I have just tried this procedure and ruined a webcam sensor (ripped it off the pcb) so I don't recommend it.
EDIT
The first casualty of this miss-adventure, don't think it is still worth £7 !
21-01-2020 #226
I suspect this is not the greatest limitation on the acuracy of your system. Making the concrete floor of your shed more rigid should be a higher priority.
21-01-2020 #227
You may think that Kit, however I believe the (presumably linear) interpolation on the sensor is messing with my non-linear intensity fitting algorithms. It makes no sense to resolve down to sub-pixel resolution when 75% of the sensor information is estimated (Nyquist would have a fit).
For example imagine the raw intensity at the peak of our gaussian laser line looks like this:
100, 100, 101, 101, 100, 100
Now if this falls under the bayer filter on a green+red filter line arranged as:
G, R, G, R, G, R, G
With only red laser light, nearest neighbour linear interpolation would look like this:
100, 100, 100, 101, 100, 100
If the bayer filter is offset 1 pixel the other way you would get
100, 100, 101, 100, 100, 100
Therefore you have 1 pixel (3um) uncertainty and this is for a green+red filter line. I think is worse for a green+blue filter line where all the information is interpolated, i.e the information rate is zero.
I have some ideas to detect and strip this out but it is guess work without a datasheet for the camera chip, or maybe just reduce the resolution of the system from 1 pixel to say 4 pixels (6um).
I have a few RPIs here with cameras which I can get the raw bayer data from and just use the red pixels (can't get the raw data from a webcam), might we worth an experiment but would need entirely new code.
An alternative would be to use an IR laser as the bayer filter is transparent to IR therefore the sensor will behave as monochrome at full resolution, but then you couldn't see the laser for rough alignment.
Monochrome usb cameras (that are made without the bayer filter) are expensive as there is no mass demand.Last edited by devmonkey; 21-01-2020 at 10:53 AM.
30-01-2020 #228
Wow ... I stopped visiting this thread on page_15 when it went quiet after my post.
I have a lot of reading to do !!
MichaelG.
30-01-2020 #229
30-01-2020 #230
Been a bit busy with other jobs, however I have been playing around with a raspberry pi version of this system. I took a PI zero W (with builtin wifi), a small TFT screen and an OV5647 (pi camera v1) and wrote some more software. This will form a simple standalone unit and addresses a number of the problems I was having with a simple webcam, specifically:
1. I access the raw camera sensor directly, read the bayer data and only use the red pixels. This removes a load of noise that was being introduced by the blue an green channels and interpolation. There is no interpolation done at all on the sensor using it this way which means I get the true intensity per (red) pixel. Pixel pitch is 1.4um and 1/4 are red so system resolution is 2.8um.
2. Vertical range is much improved around 4mm.
3. With lens removed there is no glass (or a very very thin glass maybe) over the pixel array unlike the VGA webcam which had about 0.5mm of glass which gave some diffraction patterns.
4. I put in an algo to dynamically adjust the exposure, this means I increase exposure until the detected gaussian starts to clip (sensor saturates) then back it down a bit. This makes things much more accurate and repeatable at varying distances from the laser source.
5. No more cables!
I printed a case for it today and mounted the camera to a piece of Aluminium, still need to fix it all together. It has a lipo cell on board that I salvaged from a dead rc pack, a usb charger / ups and lasts for about 3 hrs before needing recharging.
Cheers, Joe
There are currently 19 users browsing this thread. (0 members and 19 guests)
WANTED: K40 laser
By dfox1787 in forum Items WantedReplies: 0Last Post: 23-10-2018, 08:34 PM -
Newbie - Help With Laser Cutting Speed And Power - 60W Laser
By nickpscott in forum Laser Machines & BuildingReplies: 2Last Post: 11-11-2015, 10:07 PM -
FOR SALE: K40 laser not working (laser fires)
By calida in forum Items For SaleReplies: 0Last Post: 31-03-2015, 08:45 PM -
WANTED: GCc Laser Pro or Epilog Laser Cutter Machine
By Brownhills school in forum Items WantedReplies: 1Last Post: 10-05-2012, 04:30 PM -
help with cnc laser
By swinds in forum Laser Machines & BuildingReplies: 11Last Post: 09-01-2012, 10:15 PM
