24-01-2020 #2
For a router cutting mostly wood, plastics and the occasional bit of light aluminum work then wouldn't go past 700mm cutting width with a single screw. However, the gantry design comes into play as well and needs to be built a little stronger as you get wider.
45x90 or 40x80 is a minimum I would use and again depends on the machine size and design. To give you some idea this machine design I build use's only 45x90 and it will happily cut everything up to aluminium.
The machine in the picture uses a single screw and as a cutting area of about 600 x 1000 if I recall correctly. However, I've built lots of machines with this design up to 700 x 1250 cutting area using single screws. If you wanted stronger machine at the same width/length say for cutting mostly aluminum or Hardwoods with heavy cuts then go with twin motors every time.
NEW MEMBER: Hi and a couple of questions.
By TheBoltonian in forum New Member IntroductionsReplies: 4Last Post: 08-01-2017, 05:58 PM -
WANTED: Supported rail - a couple of lengths of any size for an experiment!
By GND in forum Items WantedReplies: 0Last Post: 29-11-2016, 02:16 PM -
hi all, new to cnc building,couple of questions if anyone can help. TIA
By universally in forum Gantry/Router Machines & BuildingReplies: 14Last Post: 18-01-2015, 04:12 PM -
Beginner MYCNCDIY Mill Build questions
By suraj1793 in forum Gantry/Router Machines & BuildingReplies: 35Last Post: 15-11-2014, 06:28 PM -
NEW MEMBER: Hi there, a new member from Mid-Wales with a couple of daft questions.
By m0nk3hjam in forum New Member IntroductionsReplies: 6Last Post: 17-08-2010, 02:32 AM
