Thread: Losing steps/position, again
09-04-2020 #10
See here you go again giving out wrong information and not understanding how steppers work.!!
First, it's 27mh in series not parallel and that isn't uncommon when wired in series. For our needs with routers, it's 6Mh which just means it's a shit motor and to give it a wide birth.
It's a known fact that motors wired in series have higher Mh and require higher voltage if you want speed from them, this is why most of those you list have high inductance. If you look all except the third on list only have 4 wires and are probably Series wound motors.? Again anyone who fits these to a router is a moron who didn't do his research.!
However, all of this doesn't change the fact that your advice that "Doesn't matter wether you have Nema 17/ 23/ 34size motors etc, the drivers regulate output voltage to the motors themselves." is seriously wrong and potentially dangerous if took to the extremes ie: 240Vac drives with nema 17 motors.
I'm done with this now.!!
Losing steps
By Edendale in forum General DiscussionReplies: 11Last Post: 06-03-2020, 10:10 PM -
Weird noise on travel and losing position
By ngwagwa in forum Artsoft Mach (3 & 4)Replies: 12Last Post: 07-02-2020, 05:45 PM -
Router losing steps. Solution needed. Will this help?
By cncbobuk in forum Chinese MachinesReplies: 9Last Post: 27-12-2017, 03:40 AM -
Losing steps on Z axis
By Arzo10 in forum Machine DiscussionReplies: 15Last Post: 31-03-2017, 10:49 AM -
New Mill losing steps
By lukecnc2012 in forum Gantry/Router Machines & BuildingReplies: 42Last Post: 08-11-2014, 02:56 PM
