    For Z do i need both limit and home?
    Generally you don't use a bottom limit switch but you can use soft limits. on all axis.
    I've gone with common sensors for limits and homing plus soft limits. Sooooo easy in LinuxCNC. I have a low limit switch on my Z axis, but that's because on my design there's a crash risk with the gantry ends if it gets too low. There is a soft limit as well so it's really belt and braces.
    In practice you should never need limit switches to prevent a crash as long as you have the soft limits set correctly and always home the machine before you do anything else after switching it on.
    BUT. There may be a risk if you have a pendant for manual control of the machine which does not operate through the controlling software and therefore moves the machine without the software knowing. I think this is possible with some of the cheap Chinese break-out boards and is a train-wreck waiting to happen for the blissfully ignorant.
  1. NEW MEMBER: Production grade CNC router Vs Homebuilt CNC router advice
    By SweetAs in forum New Member Introductions
    Last Post: 16-02-2019, 12:06 PM
  2. Replies: 4
  3. what router can i use with openbuild ox gantry router?
    By davejavu123 in forum OpenBuilds OX CNC Machine
    Last Post: 13-08-2015, 01:40 PM
  4. eBay: CNC Router - EXELCNC HD1013 - Heavy Duty CNC Router
    By Deuce_Coupe in forum Items On eBay UK
    Last Post: 16-07-2014, 11:46 AM
  5. Woo, my first 'proper' part!
    By craigrobbo in forum Woodworking Project Showcase
    Last Post: 05-08-2012, 02:51 PM
