Hmmm, you're right - it instead refers to a relay coil with a +/- nomenclature on the coil - okay if the relay integrates a back-emf diode - I've seen relays with these - but never experienced them myself. Worth being vigilant on that topic - otherwise you can risk damage to the AXBB. Or drive the relay through a transistor amplifier (I'd always belt-and-brace that solution - but that's just me) - either way the solution requires a back-emf diode to protect the switching device.
The MK2P-S does not integrate a diode - you need to add one. Psst, if you don't have one PM me your address and I'll pop a couple in the post - I'm heading to the PO this afternoon anyway.
22-09-2020 #2
BUILD LOG: Quite an Unusual one
By Boyan Silyavski in forum DIY Router Build LogsReplies: 205Last Post: 18-04-2023, 06:04 PM -
An unusual problem
By racerbear02 in forum Machine DiscussionReplies: 5Last Post: 10-01-2016, 11:45 AM -
Unusual Knife Block
By Christian Knuell in forum Woodworking Project ShowcaseReplies: 1Last Post: 10-09-2014, 11:28 AM -
Which air compressor?
By newtoid1986 in forum General DiscussionReplies: 7Last Post: 12-12-2011, 04:07 PM
