Thread: 6040Z controller
Cutting air is very cheap, and a good way to play with the machine. ESPECIALLY whilst you have noise in the system.
27-10-2020 #2
Plus one for cutting air
Another option is to cut insulation foam board it’s normally in 50mm thick prices cuts with a bread knife and machines good enough to see what you have cut and measure it reasonably accurately but if the shit hits the fan it’s normally soft enough to not break the cutter
I’ve seen 5axis machines at work cut a block of foam for 20 hours or more before the cutter is introduces to a £20k worth of titanium billet
Paul
6040Z USB CNC - USB port not recognised.
By Roy in forum Chinese MachinesReplies: 9Last Post: 23-05-2021, 10:04 AM -
Usb controller
By pemmott in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 02-12-2019, 07:34 PM -
6040Z USB connection issues
By rogw in forum Chinese MachinesReplies: 8Last Post: 01-08-2019, 08:30 PM -
CNC 6040z USB z-axis
By Sashido in forum Chinese MachinesReplies: 19Last Post: 26-03-2018, 09:46 AM -
Engraving small font - the bit digs deeper and deeper as the job goes on. 6040z
By xoneeleven in forum Chinese MachinesReplies: 46Last Post: 26-04-2016, 12:06 AM
