Thread: Gear reducing kit recommendation
Yep you'd be Stoopid, but obviously, I'd say that if you were correct but your not:.
All you would be doing is changing the effective pitch and not applying any ratio for either torque or resolution. For instance, working with a Mod1 rack. 60T pinion would give you an effective pitch of 60 x 3.141 = 188.5mm per/rev and if you used 20T your still at 20*3.141=63mm pitch. Far too large for most machines.
So even with 20T pinion, you'll still want 3:1 for a router or similar. You also don't want to direct drive off the motor for resonance reasons.
Now to the OP, I would just make your own setup using pulleys, etc.
It's often cheaper and comes with the added advantage of easy ratio adjustments but more importantly, it lowers the amount of resonance which affects the motors. Timing belts are also low backlash.
Gearboxes are ok but limiting if you are not sure on ratios and because they are direct drive to the motor they can introduce substantial resonance into the motor. You also need low backlash gearboxes which are more expensive than the run of the mill gearboxes.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
28-11-2020 #2
Reducing 12v DC to 0.5V DC no more than 1A draw
By AdCNC in forum General ElectronicsReplies: 18Last Post: 31-12-2022, 08:14 PM -
Simple 3D Gear design software recommendation
By Leadhead in forum CAD & CAM SoftwareReplies: 22Last Post: 11-11-2017, 01:30 PM -
Reducing noise during run with box enclosure
By Skydeals in forum Machine DiscussionReplies: 4Last Post: 12-02-2015, 08:43 PM -
Reducing costs
By tonygagey in forum Gantry/Router Machines & BuildingReplies: 16Last Post: 13-08-2014, 11:33 AM -
My first gear, a deadbeat escapement gear for my clock
By clockman in forum Woodworking Project ShowcaseReplies: 9Last Post: 30-01-2011, 11:39 PM
