Thread: Does this sound normal?
22-06-2021 #21
Ok well, 15mm isn't a common pitch size but they do exist. However still, things don't add up.?
The drives are set for 2000 micro-steps and your direct drive to the motors. 2000/15=133.333333 Steps Per mm.
If we work it backward just in case the drives dip switches are telling porky's then from the Mach3 Auto calibrate setting 125 steps per with 15mm pitch this would give a micro-step setting of 1875.? I've never seen drives that allow this setting and the manual doesn't show it either.?
So something isn't adding up here at all.
Regards the G0 y100 command then it will move to y100 coordinate position which doesn't mean it will necessarily move 100mm. If you Zero the DRO then it should move 100mm.
To move a set amount without worrying about the coordinate location then you need to switch to incremental mode, try this next time.
G91 G0 y100 and it will move the amount asked for from the current location. When finished type G90 to put back into absolute positioning mode.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
22-06-2021 #22
Sorry to hear you have joined the club, its not a good club to be in.
http://www.mycncuk.com/threads/14563...-router-review
The Following User Says Thank You to andy_con For This Useful Post:
23-06-2021 #23
Andy, did you get this resolved? I got in touch with him yesterday and he said he will be sending out replacement upgraded controllers which have much smoother output. We shall see. I will update this thread if I receive the kit.
I have been looking at the AXBB-E controller with closed-loop servos. Obviously, in hindsight this is the right gear for the job but it is my fault for not putting enough research into this. I just have to make the most of the situation and get it sorted as best I can.
23-06-2021 #24
Hi Grant, I know we have spoken and emailed so you know most of this but I'm saying what's below for the sake of others reading this.
It's not just as simple as swapping out the drives, motors and PSU also need to be factored into the equation.
I would want to know the specs of the motors and the inductance ratings, etc because usually, it goes hand in hand that if used cheap drives they will have used cheap motors probably bought together as a kit.
It's very common for Cheap NEMA 34 motors to have very high inductance which means more voltage is required to get any decent performance so just changing the drives won't always make much difference to performance.
Having a good machine is all about balance and how the components match up with each other and the machine in general regards ball screws etc.
BULLSHIT can baffle the unknowing or unweary so be very careful because you are about to walk into a minefield of BULLSHIT
23-06-2021 #25
Do you need to use more than 4 axis?.
I know of another guy who has the AXBB-E. It is a good unit however.....
If you want to use a 5th or 6th axis you need another breakout board to go into channel 3's non isolated IDC port.
The optocouplers on the isolated channel 2 outputs aren't fast enough for pulsing by the looks of it.
He got a UCSB board for chnl 3 and all is well.
Other than that they're decent units.
I had the 'kit' type electronics on my mill and almost the whole lot has been replaced due to lack of performance.
Went with the UC300eth, UCBB, and was going to switch to closed loop gear later on.
Closed loop is a little misleading though so I'm hoping to eventually change to Lichuan servo's instead.
23-06-2021 #26
23-06-2021 #27
The motion controller is exactly the same one as the UC300, the only difference is the I/O board of the AXBB-E only provides 4 Axis outputs with provision for 2 more using an external breakout board. Other than that the motion controller side and performance are exactly the same. The only reason really to use a UC300 over the AXBB-E is if you need more I/O for things like ATC, etc.
There is nothing misleading to the closed-loop stepper system, it does everything it says on the tin.? It's people misunderstanding the difference between steppers and servos which causes confusion.
The loop is closed back to drive using the encoder for error checking just like a Servo works and if the error threshold is exceeded the drive faults.
The BIG difference is in the power and performance of AC or DC Servo motors compared to Steppers, how they actually work regards closed loop is very very similar.-use common sense, if you lack it, there is no software to help that.
23-06-2021 #28
I only need the three axis. xyz.
Why do you say closed loop is misleading?
Hypothetically if I did need to upgrade, what would be a suitable setup? Now I do realise that the quality of cnc equipment lies on a very broad spectrum of quality standards and that there are unlimited combinations available, making my question nonsensical to seasoned veterans here. However.....in my situation where I will be cutting exclusively wood (soft and hard), possibly a few hours a day, on a sturdy metal frame with 15mm ball screws attached - what would a proper setup look like?
4 x Nema23 closed loop. (2 for X, 1 for Y, 1 for Z)
AXBB-E controller with accompanying software.
2 x Power supply ( 1 for X and 1 for Y and Z)
Controllers (Do I need 1 for each motor drive?)
23-06-2021 #29
That's the plan (If I can get the machine to fund it itself). I'd love to have a go at making an ATC just for the fun of it.
Also. I prefer to have seperate components. Yes it can be a higher outlay but it's then cheaper to replace individual parts later on if one fails.
With closed loop..... I suppose it depends on what components you get. I've seen plenty of good/bad experiences over on cnczone. Mostly the HBS drivers.
23-06-2021 #30
Ask JAZZCNC (Dean) about the Lichuan A86 drivers and 2102 motors he has if you're serious about closed loop.
One of the best options in the u.k. atm afaic.
You can hook those up directly to a 55vac toroidal power transformer for simplicity.
The AXBB-E has enough outputs for 4 axis, spindle and ancilliaries straight out the box (3+ slave in your case).
Initial outlay is a cost but..... you won't be constantly pratting about with a setup like this if you wire it correctly first time.
The documentation on the Lichuan is ok and I'm sure Dean will help you out.
Is this normal?
By Pete147 in forum Control Hardware & SystemsReplies: 5Last Post: 03-06-2021, 10:24 PM -
Is this normal?
By A_Camera in forum Belt Drive, Pulleys & TimingReplies: 19Last Post: 28-04-2021, 08:12 PM -
Looking for an economical XY (well and Z) solution that is not for the normal use
By SparkyLabs in forum Linear & Rotary MotionReplies: 27Last Post: 23-12-2020, 09:49 PM -
1st time setting up.. whats normal..
By Marlin in forum Motor Drivers & ControllersReplies: 26Last Post: 01-09-2014, 04:53 PM -
Looks like the normal first page has gone awry.... or is it my PC?
By WandrinAndy in forum General DiscussionReplies: 22Last Post: 03-10-2012, 08:05 PM
