    Lives in East Lothian, United Kingdom. Current Activity: Viewing Forum Superstar, has done so much to help others, they deserve a medal. Has a total post count of 2,990. Received thanks 374 times, giving thanks to others 9 times.
    I've not really been following this thread, but the simplest option is a 4PDT relay as has been suggested, but you only need to switch the Dir+/-, and Step +/- signals.
    Driver is permanently enabled, so you don't have to worry about it losing power and the Z dropping.
    And the GND is only needed for the main power, as the driver inputs are optoisolated.
    The only issue with using a relay is with switching such a small current, the contacts will likely oxidise with use due to lack of current to wet/clean the contacts, eventually leading to lack of continuity,
    For a circuit only switching occasionally, it'll likely be a long time before failure is likely to be an issue, but it's something to bear in mind.
  2. The Following User Says Thank You to m_c For This Useful Post:
  3. #2
    That is only true if he ALWAYS wants to have the stepper energised and always holding. That is not always desirable or even advised. So unless you absolutely certain that he doesn't care about enabling/disabling the driver it is indeed necessary to switch the enable signal also. Regardless of which, there is no harm in switching it, but there can be harm in not switching it.
    GND is the same as STEP - , DIR - and EN -. It is better to connect those to the same - output as the one providing the control signals. Again, it would do no harm and we know too little about his design and implementation.
    That's why I said that a small signal relay needs to be used, not a contactor. You talk about a contactor which is designed for high voltage and current.
    If you'd looked at the relevant photo, you would see the Enable on the driver has nothing connected to it, plus there is also the post stating he doesn't want the axis to become disabled to avoid the axis dropping, so connecting the enable is not needed.
    Not on the existing step source, as again, the photo shows differential outputs.
    However I did think about this earlier, as the alternative controller may not have differential outputs, so some thought may be needed in that regard.
    All relays, apart from specialist relays have minimum switching currents. It is not something that only applies to contactors.
    Good relay manufacturer's will publish the relevant detail in the datasheet.
  1. How to wire the enable pin on a stepper drive?
    By cncJim in forum General Electronics
    Last Post: 01-01-2016, 05:10 PM
  2. WANTED: parker CD20 stepper drive
    By drumsticksplinter in forum Items Wanted
    Last Post: 29-03-2014, 03:35 PM
  3. Wanted: Parker CD20 Stepper Drive
    By drumsticksplinter in forum Classified Ads, Buy, Sell & Swap
    Last Post: 29-03-2014, 03:33 PM
  4. What voltage for stepper drive?
    Last Post: 22-01-2014, 10:49 PM
  5. BOB & Stepper Drive
    By GTJim in forum General Electronics
    Last Post: 22-08-2013, 07:17 PM
