Thread: 4' x 4' x 8" Router Build
#4 Depends on the quality of the wire, the wire on the Lichuan motors we use isn't shielded and we never have any noise issues from it, only on very long wire runs ie: 8x4 or 10x5 machines do I tend to fit shielded cable but even then it's only precautionary thing and I doubt would have trouble based off the other machines we built.
#7 We don't connect this as it's given me problems in the past with noise, if the chassis/gantry is earthed then you won't have any issues.
#11 Permanent 24v and 5V supply otherwise you'll drop power to the Axbb-e and lose your Workoffset if you haven't saved it first, UCCNC only saves the Workoffset on shut down so if you haven't saved the offset then it will be lost with a power cut. It's also a pain in the arse having to restart UCCNC, reload the G-code etc just for an E-stop.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
01-12-2022 #2
I'm assuming this is something I could easily upgrade if the need arises once I'm up and running? The cables I have came with 3m extension cables, hopefully these will be long enough.
OK, I'll leave it un-connected. The cable from the VFD to the spindle needs to be shielded but with the shielding only connected at the VFD end and not to the spindle connector - is this correct?
I'm referring to the 24V to the isolated inputs, the 24V and 5V power connections to the AXBB-E are permanently connected. Should the isolated inputs be permanent too?
02-12-2022 #4
02-12-2022 #5
No, sorry I meant to say shielding not earth, but yes the shielding for that group of wires, not the connections themselves...
So I'm talking about the control wire you would also install so that the main cnc controller can control your VFD from software.
Also, I think you should choose Doddy's advice and mine on this one and definitely connect Pin 4, it costs nothing to do and I too would rather sleep well at night knowing your/my spindle housing is properly wired to be safe in a fault condition.
Earth/ground is there for safty first and should be used as intended, using it for noise drain should be considered as a secondary bonus feature in this application in my opinion.
Noise issues can be isolated and remedied, restarting your heart isn't as easy to do...Last edited by Lee Roberts; 02-12-2022 at 01:37 AM.
The Following User Says Thank You to Lee Roberts For This Useful Post:
BUILD LOG: Router Build Mk 1
By hoppo in forum DIY Router Build LogsReplies: 19Last Post: 14-08-2017, 08:31 AM -
Router build
By Blackrat in forum Gantry/Router Machines & BuildingReplies: 39Last Post: 18-12-2014, 07:19 PM -
RFQ: Does anyone want to build me a cnc router?
By totally useless in forum Projects, Jobs & RequestsReplies: 31Last Post: 08-05-2014, 09:55 PM -
BUILD LOG: My Router Build!
By andy0202 in forum DIY Router Build LogsReplies: 3Last Post: 31-01-2013, 08:51 AM -
BUILD LOG: A3 Router Build
By GTJim in forum DIY Router Build LogsReplies: 6Last Post: 17-02-2012, 12:53 PM
