Thread: Maximat V10P runs out
27-12-2023 #11
The spindle itself won't adjust.
The entire headstock assembly will need to be adjusted.
It's possibly done by the grubscrews (No. 48), but there will likely be some correct order to do the adjustment. Probably slacken the main mounting bolts, adjust the grub screws, then re-tighten. You may need to fully remove the headstock to work out how they adjust, but you'll have to be aware of any shims that might have been used.Avoiding the rubbish customer service from AluminiumWarehouse since July '13.
Replaced faulty driver, now that axis runs in reverse
By WRandall in forum Gantry/Router Machines & BuildingReplies: 5Last Post: 31-10-2018, 07:42 AM -
RFQ: Looking for cnc turning of prototypes and if possible small production runs
By Rob in forum Projects, Jobs & RequestsReplies: 0Last Post: 16-01-2016, 01:27 PM -
FOR SALE: Emco V10p for sale
By compositepro in forum Items For SaleReplies: 1Last Post: 07-09-2013, 05:46 PM -
Emco Maximat V-10 P
By Nielsvrijlandt in forum Emco LathesReplies: 1Last Post: 28-01-2011, 10:19 AM -
How to make a pickup winding faceplate that runs 'true'
By HankMcSpank in forum Milling Machines, Builds & ConversionsReplies: 8Last Post: 09-09-2009, 12:16 AM
