Thread: MY 4`x 4` table
    A floating z axis, so you're going to use the 3 ball arrangement to set the torch height. It does sound heaps easier than faffing about measuring the volts. This could be up and running PDQ.
    Looking good. We'll need a movie when you get it cutting :D
    Hi Robin
    actualy no Im not going down that balls route, the idea is to put a limit switch on floating "Z" and use as a ref, bring "Z" down torch will touch metal and lift floating "Z" into ref switch, and stop then lift "Z" by a known amount (switch travel + clearance of tip) and fire, this way every start will be automaticly set to differing thicknesses of material, as the distance of lift will be a constant. well thats the plan, Mach3 has this ability
    Steve
    Hi all
    Just a bit of a update, I have spent a few weeks collecting bits for the controller, and this is what I have, Campbell Designs excelent Break out board, a Sound Logic Power board with a 500va transformer together they give me 50v dc, and Gecko G203 Vampire drives (Im still 2 short but funds allowing I will order those this week), all in a 2U rackmount case with power and E Stop on front and all plugs on back
    Steve
  1. Setting my table up...
    Last Post: 10-03-2014, 08:24 PM
  2. DIY Vacuum Table
    By templecorran in forum Machine Discussion
    Last Post: 10-11-2010, 12:11 AM
  3. RFQ: RFQ: Plasma Table
    By D-man in forum Projects, Jobs & Requests
    Last Post: 04-07-2010, 11:08 PM
  4. Plasma table 2m x 1m
    By Robin Hewitt in forum DIY Plasma Build Logs
    Last Post: 19-05-2009, 12:48 PM
  5. Clamp table
    By Lee Roberts in forum Programmers Corner
    Last Post: 14-10-2008, 03:03 AM
