Thread: Plasma/Router combo
17-09-2010 #2
You could share the X axis rails and ballscrew - you'd just need to bolt the ballnut to the gantry you wanted to use. The plasma gantry would be relatively cheap to build as it doesn't need a powerful motor or high stiffness linear bearings.
One consideration would be choosing an X axis stepper that had the torque for routing and the speed for the plasma but you could always gear it and swap the sprockets over.
17-09-2010 #3
Yes I wasn't suggesting that two sets of screws/rails would be needed for the X axis. Good point about not needing high stiffness bearings...what about these:
http://uk.rs-online.com/web/search/s...duct&R=4485499
They're rated for high speeds, and cheap...
Yes I think having a pulley/timing belt on the X axis is a must. Thinking about it if you had pulleys on all the axis then perhaps one could get the machine fast enough with the milling gantry since it could, with a bit of experimentation, be geared for much higher speeds since you no longer care about cutting force.
LIMAC knife cutting machine and plasma machine, cnc router latest video
By therouterlady in forum Manufacturer NewsReplies: 0Last Post: 18-09-2013, 05:28 AM -
How can I find fast stepper motor / controller combo?
By JuKu in forum Stepper & Servo MotorsReplies: 2Last Post: 23-07-2013, 12:32 PM -
My first CNC plasma
By Walterronny in forum DIY Plasma Build LogsReplies: 30Last Post: 20-02-2013, 02:13 AM -
NEW MEMBER: Have Built 2 CNC machines 1 mill/drill conversion and 1 Router/plasma from scratch
By AGB in forum New Member IntroductionsReplies: 3Last Post: 06-02-2013, 03:16 AM -
FOR SALE: CNC Plasma / Router for Sale
By Normsthename in forum Items For SaleReplies: 9Last Post: 02-10-2012, 09:16 PM
