24-12-2010 #5
I take it the hardware is made by CDE also, if so that i suspect is the problem (Hardware).
To test i would remove the motors from the machine run the code and see if any motor stops when it shouldn't. That will eliminate any machine binding issues.
I would also check the power supply voltage they have some pretty low output votages, i just cut my losses and sold the system.
Phil
Warco WM16 Mill - Conversion to AC motor with VFD
By birchy in forum Milling Machines, Builds & ConversionsReplies: 16Last Post: 10-02-2022, 07:41 PM -
CNC Turret Mill range
By newtoid1986 in forum Milling Machines, Builds & ConversionsReplies: 0Last Post: 28-11-2011, 07:23 PM -
Warco WM16 Conversion
By birchy in forum Milling Machines, Builds & ConversionsReplies: 21Last Post: 25-03-2011, 09:32 PM -
Warco mini mill cnc conversion
By buster in forum Milling Machines, Builds & ConversionsReplies: 22Last Post: 20-03-2011, 07:48 PM -
CONVERSION: Buget Warco Major 5 axis conversion
By Tweaky in forum Conversion Build LogsReplies: 45Last Post: 07-10-2010, 04:26 PM
