Thread: Fingers crossed it'll cut ally
Wait a second. I can just make you one using a PIC ... it'll save you buying one and you won't have to modify it.
If you just measure the voltage at the point I said earlier. Remove that resistor (R32), remove R31 and connect the parallel port pin to where R31 connected to the potentiometer, then set spindle in mach3 to highest, adjust the pot so you get the same voltage as measured at R32 earlier. Put R32 back in place and do not move the potentiometer ever again otherwise the microcontroller will probably break.
Measure that voltage, if it's ok then I'll scribble a diagram over the picture you posted.
It would be good if a moderator could split this thread up to save duplication? If not then I'll start a new one about the spindles.
12-01-2011 #2
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM -
FOR SALE: 45 by 90 ally profile
By johngoodrich in forum Items For SaleReplies: 5Last Post: 13-09-2011, 06:45 PM -
RFQ: anyone wanna quote me to cut some ally?! and....
By robmurf in forum Projects, Jobs & RequestsReplies: 2Last Post: 01-09-2010, 01:16 PM -
NEW MEMBER: anyone wanna quote me to cut some ally?! and....
By robmurf in forum New Member IntroductionsReplies: 2Last Post: 01-09-2010, 10:31 AM -
Model Engineering Exhibition @ Ally Pally
By irving2008 in forum General DiscussionReplies: 6Last Post: 18-01-2009, 10:15 AM
i guess i should have split it up into spindles router and vacuum stuff
