Thread: Stepper Motor Wire Colour Codes
14-01-2011 #1
HELP, is there a standard colour code for nema moters?
IE what wire doz what!!!!
14-01-2011 #2
Try these
http://www.mclennan.co.uk/datasheets...ppermotors.pdf
It would also help if you quote the model number
peter
14-01-2011 #3
well yes I could ,, and will doo tomoz ,, and be very thank full if you can help but the question is
Is there a standard colour code for nema motors ?
there should be , they are standardized motors arnt they??
found it !!
they are 57bygh633
1.8 deg
3 amp
made by Wantai motor
6 wires B,W,R,G,Y,B
14-01-2011 #4
Goggle is a good friend http://www.google.co.uk
http://www.kysanelectronics.com/Prod...?recordID=3575
Phil
14-01-2011 #5
16-01-2011 #6
AFAIK the NEMA standard for motors only standardizes the sizes of the mountings i.e. all 23s are the same all 34s etc.. I'm pretty certain there is no standardization of wire colours. Here's a killer example that makes it even worse than you might at first think. The M60STH88 (a replacement for) and the FL60STH86 have the same colour wires and they all refer to the same "coil ends" if you see what I mean - BUT the STARTS of the coils are different! Bit me right in the *ss that one!
16-01-2011 #7
Yes I've had many different colours of wires on steppers. You often find they're quite logical colours - i.e. the similar ones go together.
size 23 = 2.3"
size 34 = 3.4"
etc
24-01-2011 #8
Well jonathan has come up with the solution of all the heat was running at full power , too hi .
turned the board down to 3a and now a lot better so far , is there a better way of wireing the moters?
24-01-2011 #9
24-01-2011 #10
I was but aparently there is no standard colour code for the wires got the nema 23 size ones infront of me and they have 6 wires
these are BL,G,R,B conected to the board A+,A-,B+,B- white and yellow not used at all
I can follow a wireing diagram but as to the indeph tecnical stuff with electirkery I am a bit fooked
Jonathan gave me the ides to turn the power down on the controler board which has worked
they have been running the roadrunner for 2 hours and only luke warm now
as for bipolar ECT just dont know as the wireing crapagram dont actualy say which is which
Any help M8 ?
Stepper wiring/colour coding
By rwb97 in forum Stepper & Servo MotorsReplies: 24Last Post: 23-06-2014, 11:34 AM -
VFD to motor cable wire size (Gauge)
By artman12us in forum Spindles & Drive MotorsReplies: 2Last Post: 24-04-2014, 07:11 PM -
3 wire stepper motor drivers?
By m_c in forum Stepper & Servo MotorsReplies: 0Last Post: 17-08-2013, 10:01 PM -
common wire on stepper motor question
By progomez in forum Motor Drivers & ControllersReplies: 1Last Post: 27-10-2009, 11:56 PM -
Motor controllers/drivers/wire ?!?
By Lee Roberts in forum Motor Drivers & ControllersReplies: 8Last Post: 24-08-2007, 08:46 PM
