Thread: Leadscrew
27-02-2011 #4
Thanks guys, by resolution you mean what measurement divisions "on the dial" so to speak?
Well because of the purpose i don't think measurement is critical, i'm building a recording lathe (that records are made on). The cutter carriage has fixed start and end points for the cutting range other than that the actual measurement i don't think is critical. So the answer is i don't know!! But the feed rate must be down to about 2mm/min. Are there methods for working out what i need?
I posted a pic of a commercial recording lathe in another post here:http://www.mycncuk.com/forums/showth...siastic-Newbie
leadscrew conversion thoughts
By GEOFFREY in forum Lead Screws, Nuts & SupportsReplies: 21Last Post: 18-12-2012, 12:56 AM -
Cheapo Leadscrew with minimum accuracy requirement!
By Vikash in forum Lead Screws, Nuts & SupportsReplies: 16Last Post: 06-10-2010, 11:17 AM -
(Mini Lathe)Potecting Leadscrew
By GeorgeD in forum Milling Machines, Builds & ConversionsReplies: 17Last Post: 29-09-2010, 11:48 AM -
Ron Steele Mini Lathe CNC Conversion - Z Axis Leadscrew?
By No1_sonuk in forum Lead Screws, Nuts & SupportsReplies: 6Last Post: 17-05-2010, 12:47 PM -
Where did you buy your threaded rod?(cheapo leadscrew!) - was it straight?
By HankMcSpank in forum Marketplace DiscussionReplies: 18Last Post: 04-06-2009, 03:44 PM
