Thread: Rotating Ballnut - design ideas
11-04-2011 #10
Yes that's static, forgot to mention that! I can't find a rating for dynamic, just interesting explanations about how the bearing responds to axial load.
Fair enough, those are both clearly important for this application.
According to the SKF site the axial internal clearence for a 40mm bore double row angular contact bearing is 11um. So that's like having 11um end float on the screw if I used the design with the single bearing. I'm not sure how bad that amount is - it doesn't sound like much. C2 clearance bearings only have 2um clearance.Last edited by Jonathan; 11-04-2011 at 12:42 AM.
Rotating Ball nut
By drumsticksplinter in forum Lead Screws, Nuts & SupportsReplies: 30Last Post: 12-05-2020, 08:01 PM -
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Rotating Ballnut Design MK3
By Jonathan in forum Linear & Rotary AssembliesReplies: 0Last Post: 15-12-2013, 01:35 PM -
