Page 6 of 12 FirstFirst ... 45678 ... LastLast
  1. #51
    I'm ordering a cheap mouse and a Serial cable today.
    what sort of cables do I need for hooking up the breakout board, PSU and Drivers etc?
  2. #52
    Quote Originally Posted by jcb121 View Post
    Mice are handy, but what's the serial cable for? Did you mean parallel?
    For the PSU to driver you'll want something that'll conduct the required current without a big voltage drop. Probably 1.5mm^2. Some people use shielded...I don't think it's required in most cases.
    For the breakout board to drivers standard 7/0.2 wire is fine (or anything you have lying around) as it's only a signal.
    Drivers to steppers generally CY 4-core (which is shielded), 1.5mm^2. You need minimum 1mm^2 from the VFD to spindle, so the same as you use for the steppers will be fine.
  3. #53
    maplins it is then.
    parallel, yes I did mean that!
    Thanks.
  4. #54
    maplins it is then.
    Noooooooooooooooo.... they charge silly money and probably wont have the cable for steppers anyway. eBay/Rapid electronics/Farnell is your friend. I've got plenty of 7/0.2 wire (all the colours) and possibly the rest depending on how much you need?
  5. #55
    Thanks John, I may just take you up on that!
    Shouldn't need too much. I was just thinking about testing my electronic bits as I'm not even sure they work! I hope they do....
    when putting them in the machine I'll order the cables.
  6. #56
    Jess
    How are you and how is that build going
    I know you've had your problems but thats no excuse for no input or even saying hello
    James
  7. The Following User Says Thank You to luke11cnc For This Useful Post:
  8. #57
    good timing on this post as I actually have an update!
    I went to FromStock today and picked up a fair bit of ALU for my machine. all cut to size.
    I'll get a pic of it when i find a camera.
    I have enough to make my spindle mounts, and my gantry, the only alu i need now is some 50x10 and 50x20 for the frame.
  9. #58
    this is my fair bit of Alu, that's a 50cm ruler next to it and I got it for a stupid price.
    it would be unfair to tell you the price due to pure jealousy, but you can guess at it :)
    it's all 12mm thick also.
    I will be drilling some holes later, but I need an engineers square to be really accurate.
ID:	4539Click image for larger version.
  10. #59
    So if the ruler was a stupid price how much was the aluminium? Looks like about £31 worth to me...so I guess a stupid price would be £20.
    You seem to have laid it out with the Z-axis rails mounted to the Y-axis slide, not the other way round. Was that just for the photo? Putting the rails on the Z-axis so they move up and down and the bearing blocks are fixed is stronger.
  11. #60
    the ruler was £1.29, £20 is bang on.
    I'll give it ago with the rails the other way around, it's just I thought the extra weight would be a problem.
  1. Aluminium box section
    By martin54 in forum Gantry/Router Machines & Building
    Last Post: 28-10-2012, 01:13 AM
  2. First Aluminium cut
    By luke11cnc in forum Computer Software
    Last Post: 24-02-2012, 09:39 AM
  3. RFQ: Aluminium sculpture to be CNC'ed
    By dav in forum Projects, Jobs & Requests
    Last Post: 07-01-2012, 04:37 PM
  4. Aluminium passivation - for aluminium to be used outside
    By CHudson in forum Metal Finishing Techniques
    Last Post: 06-04-2011, 09:18 PM
  5. MDF or Aluminium
    By rob_colby in forum Gantry/Router Machines & Building
    Last Post: 24-10-2010, 09:36 PM
