Thread: "DeusEx"
If by vector control you mean current recirculation while stood still then yes they do.
Only really apply's if your motors are good for the extra voltage.? Most nema 23's are not when wired parallel.!! . . . . Over rating a motors voltage will give extra speed but it also creates extra heat, iron loses etc which then slowly damages the motor shortening strength and life.
20-09-2011 #2
No, I mean vector control. I wont try and explain as it's a tricky one:
http://en.wikipedia.org/wiki/Vector_control_(motor)
http://www.eng-tips.com/faqs.cfm?fid=1062
Mocha is using the same motors as I am, or at least very similar - 3Nm Nema 23 with low inductance. I've been running mine on 75V since I got them well over a year ago with no ill effects. The highest temperature I have ever recorded was 60 celcius (so at least 25C below rated) on the case which was on a sunny day when the machine had been running for a couple of hours. Most of the time they linger around 45C. I check it regularly as I have an infra-red thermometer to hand and it's something to do whilst the machine's running...good for getting estimate of cutter temperature too.
20-09-2011 #3
No need to explain I know all about torque vecter drives but are you sure these drives mean the same.? I don't see any referance to torque vector control but I do see current limiting (Half current).?
If these are the motors with 3mh inductance I've seen specs sheets flouting around for then your running them approx 20V over spec, this will sooner or later have an affect.!!
20-09-2011 #4
http://www.zappautomation.co.uk/prod...ec77476e499bf4
'The application of advanced vector control algorithm greatly reduces noise and vibration of the motors during operation, '
The link I gave in my previous post explains it better. In particular this is interesting:
'The motor operates in continuous mode rather than conventional stepping mode.The audible
noise and resonance effects associated with conventional stepping mode are effectively
eliminated.'
That sounds alike to the Gecko - although it's not full stepping at higher speeds it's applying a sine wave to each phase, so operating it like a 'normal' motor not stepper motor. Bound to be quieter and more efficient for obvious reasons.
I'm intending to implement vector control on the stepper driver I'm designing/prototyping.
Well it's been 16 months. I'll let you know if they break!
The formula you are probably using to say they are 20V over-spec (32*sqrt(L)) is almost certainly an oversimplification / guideline. I think the fact my real life experience with these motors shows the temperature is fine at 75V says it all.Last edited by Jonathan; 20-09-2011 at 12:54 AM.
"Hacking" and "Modding"
CNC machine "Spanish" model . Advice and opinions needed!
By shapebusters in forum Machine DiscussionReplies: 17Last Post: 12-03-2014, 06:21 AM -
Interesting Article "Makers unite - the revolution will be home-made"
By Fivetide in forum General DiscussionReplies: 4Last Post: 28-09-2012, 12:06 PM -
"Racks" VS "ball screw"
By C.AlveSilva in forum Linear & Rotary MotionReplies: 1Last Post: 17-04-2012, 11:53 PM -
My apologies to "Andy" for the delay ... internet connection problem
By ali hedi in forum General DiscussionReplies: 1Last Post: 25-12-2010, 06:05 PM
