Thread: Diy Brushless Spindle
If the fit of the bearings on the ER11 shaft aren't a press fit then there would be a problem. I've just discovered my bearings slide up and down the shaft!
Isn't the spindle up pressing up against the inner race of the lower bearing? So wouldn't this mean that any axial load is applied to the inner race of the lower bearing and the Bellville washers would transmit the load to the upper bearing?
23-05-2012 #2
If the bearings were a press fit the belleville washers wouldn't do anything - you must have a sliding fit so that the springs can apply a preload.
Yes for an 'upwards' axial force it's constrained - but not downwards. If it wasn't for the normal bearings and grubscrew the shaft could just fall out.
Denford router - Brushed router too brushless spindle - Help and advice please
By Tom B in forum Brushless Spindles & MotorsReplies: 4Last Post: 16-05-2016, 09:13 AM -
All-In-One Brushless Servo System
By Gytis in forum Stepper & Servo MotorsReplies: 0Last Post: 22-12-2015, 10:21 PM -
DIY Brushless spindle
By booski in forum Brushless Spindles & MotorsReplies: 2Last Post: 30-10-2013, 09:36 AM -
Using RC Brushless motors as spindle
By Jonathan in forum Brushless Spindles & MotorsReplies: 30Last Post: 20-12-2012, 08:51 PM -
Mach 3 control of DC Brushless motor?
By templecorran in forum Artsoft Mach (3 & 4)Replies: 15Last Post: 18-11-2010, 04:20 PM
