Thread: Chinese Spindles
Oh just noticed three of your links are for Ms Xing....lol dont believe all you read will you
Here was The quote she gave me...
"Elizabeth Xing:(02:14:19):
3.2 kw BT30 18000rpm spindle
motor is 110mm, OK?
Rick:(02:15:35):
ok 380v
spindle
Elizabeth Xing:(02:17:26):
2199 dollars per piece, not
including the pull stud and toolholder.
Sorry, 2177 dollars per
piece.
Reply View
Context
Rick:(02:18:10):
and
220v
Elizabeth Xing:(02:18:20):
the
same.
Rick:(02:18:43):
Ok and what price for shipping
to UK
Elizabeth Xing:(02:19:31):
Shipped by DHL, 249
dollars.Package weight 23
kg.
Any questions???
21-06-2012 #2
21-06-2012 #3
It is like those hotel rooms starting at £19 when you get there they are all booked out, Every time..
I asked her what spec were her spindles for $1920, and she has none left and it is only a guide price. and some of her spindles fall outside the top end as well..
As i stated earlier in the thread i want as much flexability as possible which meant buying a seperate motor, 9k is to high for the lower limit. As you stated earlier the motors have no power at the lower speed, I will be gearing down to 2k on spindle with an approx 0-6k motor and up to 10k if need be i will be using pulleys for this, with a little left in reserve.
take a look at the pictures you cant miss it.. when i asked her if they were "used" she just said "some" Its all too easy to blag and blame the language barrier when in fact every word is understood perfectly..
But thanks anyhow JonathanAlways bear in mind that your own resolution to succeed is more important than any other - Abe Lincoln
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
motor power and chinese spindles power HELP
By DigiSoft in forum Spindles & Drive MotorsReplies: 5Last Post: 17-09-2013, 12:17 AM -
Chinese spindles
By Colin Barron in forum Marketplace DiscussionReplies: 15Last Post: 23-08-2011, 08:58 PM -
Chinese 1.5kw Spindles
By jcb121 in forum Generic Chinese SpindlesReplies: 12Last Post: 28-07-2011, 06:20 PM -
NEW MEMBER: Spindles
By Johnp in forum New Member IntroductionsReplies: 4Last Post: 28-06-2009, 11:46 AM
