Thread: Laser cutting 10mm acrylic?
Having helped assemble a water-jet cutter that was used for cutting headliners for cars, I seriously doubt you could make a desktop version as just the bath depth required to absorb the stream makes that a non starter. Back to the original question of laser cutting 10mm thick acrylic, I would go with milling as the power of the laser would have to be strong enough to not only cut the acrylic but also resist the tendency of acrylic to transmit light along and across its structure. I have seen laser etching into acrylic and that works but has limits as well.
What are you using the acrylic for?
Is there another plastic that will do the job and be easier to work?
Is the possible production level high enough to offset the cost of the laser and the cooling equipment needed?
If you are looking for finished edges, is milling the item then having it flame polished by an out source or buying a unit to do that reasonable to cost?
Those are just some questions that came to mind about where you are in this project and things that you might want to look into.
Michael
03-09-2012 #2
Thanks for the info on water jetting Michael! Thats out then :)
Didnt know or think there might be a the light transmission problem, never worked with plastics before this project so its a learning curve!
Production levels are unknown at this stage but we are exploring our options to try and figure out (guess) how many units we could produce on a daily/weekly basis!
We have tested flame polishing the milled edges but could not get a satisfactory finish (or even come close) using a butane blowlamp. lol
Acrylic Cutting Help
By Tenson in forum Machine DiscussionReplies: 26Last Post: 08-11-2016, 08:15 PM -
Laser cutting Machines
By Want2build1 in forum Laser Machines & BuildingReplies: 44Last Post: 13-05-2014, 01:58 PM -
RFQ: 4 and 5mm steel plasma / laser cutting required, can send sheetcam files
By nobby in forum Projects, Jobs & RequestsReplies: 0Last Post: 29-04-2014, 12:36 PM -
RFQ: RFQ.. Acetal or acrylic... laser cut or routed.
By purpose in forum Projects, Jobs & RequestsReplies: 2Last Post: 12-12-2013, 12:03 PM -
laser cutting ally plate
By i2i in forum Tool & Tooling TechnologyReplies: 12Last Post: 21-02-2013, 08:47 AM
