12-09-2012 #9
The mean current will be significantly less than 12A, so a heatsink with a much higher thermal resistance could be used. On my stepper PSU, which also uses a 500VA 50V transformer with 3 motors, I used one of these (or this one) and no heatsink is required as I've never noticed the rectifier get 'very warm' let alone 150°C. Still, you can find good heatsinks for free in lots of things, or since this evidently doesn't need much you could just attach it to a reasonable size sheet of aluminium.
Agree with the calculation for the bleed resistor, but surely since the stepper drivers will be switched on until the voltage has dropped to about 20V, resistors aren't critical since the energy from the capacitors will dissipate into the motors? If you unplugged the stepper drivers before turning off the power supply then the resistor is needed, but that would be a strange thing to do since it risks breaking the drivers.
The ones you have linked to will be fine, I'd get 4. The ones irving linked to are better quality (lifetime etc), but cheap capacitors are fine for this application.
Denford Triac VMC year 2000 motors spec
By suesi34e in forum Milling Machines, Builds & ConversionsReplies: 1Last Post: 17-11-2013, 11:44 PM -
Advice on spindle inverter spec
By badgerman in forum Spindles & Drive MotorsReplies: 12Last Post: 15-09-2013, 09:26 PM -
Hiwin linear blocks HGW 20 CC - what preload to spec?
By range3rrr in forum Rails, Guideways & BearingsReplies: 1Last Post: 24-08-2011, 11:44 PM -
FOR SALE: Servo Spec gearbox's ---- Any offer considered
By Jimmybristol in forum Items For SaleReplies: 11Last Post: 30-05-2011, 11:04 PM -
System spec and Mach3
By gorbo in forum Computer HardwareReplies: 5Last Post: 23-01-2011, 03:25 PM
