22-11-2012 #3
One or two flute cutters are readily available, so if you don't mind reducing the feedrate to half or a third of what you would use with 3fl, you could use less flutes:
5pcs 1.5mm Single Flute Carbide Spiral End Mills Router Bit 6mm CEL | eBay
Can you recommend a UK Supplier for cnc router bits
By GeoDurie in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-06-2014, 10:40 AM -
The tips of my 20 mill cutter get loose ...
By hoezap in forum Tool & Tooling TechnologyReplies: 0Last Post: 06-07-2013, 11:55 AM -
Which kit would you recommend?
By ian823478 in forum Motor Drivers & ControllersReplies: 2Last Post: 08-04-2012, 11:05 PM -
1.5mm ball end mill supplier in the uk
By luke11cnc in forum Marketplace DiscussionReplies: 9Last Post: 21-01-2012, 08:25 PM -
Please Recommend me a CNC mill for....
By Gasgasbones in forum General DiscussionReplies: 4Last Post: 29-11-2010, 07:17 PM
