Nice idea, I'd love a copy of the calendar G code, or is writing it the test (in which case I fail). G.
28-12-2012 #2
The aztec PDF is at the bottom of the first page:
http://www.mycncuk.com/forums/genera...files-dxf.html
The Following User Says Thank You to D.C. For This Useful Post:
28-12-2012 #3
28-12-2012 #4
To save Jazz sending it to everyone, I've just put his copy on my webserver here. If that's a problem I'll remove it straight away. You'll find plenty of other versions on CNCzone. Bit out of date now though
I've not really got anything on-topic to add. I think if anyone hasn't got the small amount of patience required to work out how to make the machine from reading existing build logs, on this site and others, then they're not going to gain much more from a set of plans which are unlikely to meet their specific requirements.
As I've said previously, you can cut aluminium with a screwdriver or knife, so to say a particular CNC router can cut aluminium is not saying much. For me to say a machine 'can cut aluminium', I reckon it would have to be capable of reliably cutting with a 6mm single flute cutter at 1mm per pass. That's nothing special or difficult to achieve, but enough to do odd jobs without getting too bored. The next thing to do is work out what machine stiffness that requires and design to achieve that...
28-12-2012 #5
No problem with me.
I've actually got a version coded for 60Deg cutter if anyone wants it. Don't try using a 60Deg with this code it will come out all wrong and look shite.
With the CNCzone if just downloading G-code be aware it will most likely be for large sizes of 16" or 24" has that was the original sizes. Try to get the DXF if you want different sizes and be prepared to maybe do some touching up.
28-12-2012 #6
Thanks Jazz and Johnathon, I would have to use a 3.175 shank (so 3mm or 3.175) ENGRAVING bit, have various Deg points. I would also like to
have a smaller dia, say 4" or 6", but don't know if I would be able to handle or clean up that amount of code. I would certainly have to drip feed
it, and would certainly like a try. G.
28-12-2012 #7
That code is for 6" and use's 6mm 90deg bit. If you like I can knock you code up for 3.175 and the Deg of choice.?
Best PM to save sending this thread off course.
28-12-2012 #8
BUILD LOG: starting from scratch- router 1st project
By idefix in forum DIY Router Build LogsReplies: 24Last Post: 10-01-2014, 12:53 AM -
BUILD LOG: My first project: A fast router...
By Boscoe in forum DIY Router Build LogsReplies: 13Last Post: 14-08-2013, 09:34 AM -
Project CNC Router for all
By Anónio Pinho in forum Open Source Designs & PlansReplies: 0Last Post: 30-06-2012, 01:31 AM -
NEW MEMBER: New to MyCNCuk
By m1ptr in forum New Member IntroductionsReplies: 5Last Post: 28-03-2012, 02:47 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM
