Thread: Hand Ergometer
Hi M8
Just been having a look @ your project and although you have expended considerable man hours on the prototype, i was wondering if you had given any consideration to using a Shimano/sram geared rear hub ?
Just a thought.
Take care and i sincerely hope your circumstances improve in the near future.
Regards
Mike
11-08-2013 #2
11-08-2013 #3
Would the ring gears on the e-bay links not be better than plastic ?
those listed are cheap enough.
Could you use two spur gears with the correct ratio ?Last edited by mekanik; 11-08-2013 at 02:30 PM.
11-08-2013 #4
Epicyclic gears have very specific relationships. To get 3:1 the number of teeth on the ring is 2 x teeth on planet + 1 x teeth on sun gear. Without knowing the number of teeth, circular pitch and tooth form of the Nexus ring gear the chances of finding other gears to suit off the shelf is diminishingly small...
Second hand machines & their features
By navins in forum Machine DiscussionReplies: 5Last Post: 19-03-2014, 11:01 AM -
RFQ: Parts for hand ergometer (exercise bike)
By irving2008 in forum Projects, Jobs & RequestsReplies: 29Last Post: 16-09-2013, 12:46 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
