Thread: Hand Ergometer
28-06-2013 #2
Does that mean you've printed them? :)
I can't guarantee the accuracy of the drawings, I use the MOD1 profile found on the web then scaled it up 1.25 to get a MOD1.25 profile but the way I had to rotate it to get the final gear may be over/undersize. I suspect its the ring gear thats slightly under... maybe you could measure the OD and ID of the gears and let me know?
28-06-2013 #3
I just printed some 1mm thick test pieces.
I loaded the 15 and 30 tooth gears into cambam and generated a profile with the built in generator and it was exactly the same outer and root diameters (just a bit more lateral clearance in the root) so I suspect you're right about the ring gear - unfortunately cambam doesn't do ring gears (I've bumped a thread asking for them).
Measured OD on the 30t gear is 40.0mm and 21.3mm on the 15t and the tooth tip diameter on the ring gear is 72.7mm and the root diameter is 76.4 (near as I can tell - it's a bit flimsy)
28-06-2013 #4
28-06-2013 #5
Ok, looks like it's a problem with printing the internal features - let me have a look at it over the weekend - trying to learn Hadoop (if you don't know, you probably don't want to) at the moment and it's not conducive to concentrating on other stuff :-(
01-07-2013 #6
Ok, some progress. I've now got a set of gears that mesh reasonably well but I'm not happy with the print quality so I'm going to try a different slicer - the one I'm using at the moment is Sli3er and it's fast and easy to use but it doesn't seem to be the best quality. I was using Skeinforge before which is better quality output but not very friendly - I'll have another go with that over the next couple of days.
01-07-2013 #7
Thanks for your efforts on this. I'm in the process of drawing up slightly modified gears, the main difference being improvements to better support/locate the bearings and space the sun gear off the rotor boss - I may increase the thickness of the gears slightly. I'm also redrawing the supports, the rotor bosses and the planet carrier. I was thinking of 3D printing the carrier but I don't think the boss would be strong enough to take a grub screw to fix it to the axle (but what if the boss was thicker and had a slot for a nut to be inserted?). The other thought I had was 3D printing other components, the rotor bosses for example. I'm not sure about the cranks or the handles from a strength perspective, need to run the numbers. Also do you have any way to calculate the cost of a printed component?
Second hand machines & their features
By navins in forum Machine DiscussionReplies: 5Last Post: 19-03-2014, 11:01 AM -
RFQ: Parts for hand ergometer (exercise bike)
By irving2008 in forum Projects, Jobs & RequestsReplies: 29Last Post: 16-09-2013, 12:46 PM -
75 mm HAND WHEEL
By Lee Roberts in forum Programmers CornerReplies: 18Last Post: 19-03-2012, 02:58 PM -
NEW MEMBER: want buy new or second hand cnc
By buildwood in forum New Member IntroductionsReplies: 8Last Post: 20-10-2011, 05:36 PM -
NEW MEMBER: second hand machine
By steve r in forum New Member IntroductionsReplies: 1Last Post: 18-11-2009, 09:00 PM
