Thanks. I am starting to realize this.
Let me explain something.
This build is a rip-off of my design for my next build which is meant to ride on 34 name Rack and Pinion.
I spend quite some time asking people around when i designed it, so it seems the overall opinion was that a 150kg gantry is quite well driven by 34 nema rack and pinion, i mean the acceleration and deceleration. There were even people on CNCzone that insisted that the gantry behaves well if is loaded more than 130kg so they made it heavy on purpose.
So everything started as i would like to test the RP on a real build, The nema 34 would raise the price, so i went for Nema 23 and started slowly underrating my original idea.
Now Just received an answer from CNCrouterparts and Ahron tells me what i suspected , that the g540 is not up to the task and i should couple their low inductance motors with better drivers, due to possible g540 overheating during long runs.
So it seems i am insisting on the RP drives
. I like to test them and could not help . I am at the point of ordering the RP drives , racks and the low inductance Nema 23 . That means i must lower the gantry weight.
Ok, gantry weight.
Lets see. I can go back to 50 kg, complete gantry with Z, still keeping some reinforcement. Only eventual twisting should be considered, z is 300mm wide so no worry there in the other directions. Another point is that normally the jobs will be done with rough cuts by 1/4 router bits and fine passes 1/8 router bits, with passes equal to the width, routing wood as i said and that easy going special cast materials which route like MDB , so this is not a factor that would play in the final design.
Jazzcnc, i highly value your opinion. Why you believe the Chinese ball screws 2010 for example could give me better finish than the RP drives? All seem to be happy running RP drives, did i miss something? I know the table is not so big to really need RP.
22-08-2013 #2
Those people on the Zone are probably only using R&P because.!
A: They are large long machines so ball-screws are harder to use.
B: They can't afford Us made Ball-screws and the Yanks are very reluctant to Import Chinese parts.
C: The CNCRP R&P is US made so fits with above.
D: They have never used ball-screws so they don't know the difference in performance and smoothness ball-screws make.
My advise is just that "Advise" take it or leave it but I know thru experience with R&P that Nema23 motors with heavy Gantry is recipe for trouble if your wanting high feed rates.
Yes I know Nema 34 will handle heavy gantry ok and that heavy helps with cutting but Heavy and high feed rates is a completely different issue.!
Combine this with 3D work which requires Small fast direction changes and this issue becomes worse.
Now the difference between R&P and ball-screws is several.
Ball-screws are much more efficient so don't require has much power to turn, typical efficiency for Balscrew is 90%+ were R&P is 60% or lower.
Ball-screws have much lower backlash so are far more accurate and repeatable. R&P is quite high backlash and not easy or cheap to make real antiback lash using correct pinions.
R&P resolution is much lower and to get higher resolution requires at least 3:1 gearing this in turn means steppers need to spin fast and has you may or may not know torque drops off fast at higher speeds on steppers and even more so on Nema 34 motors unless running really high voltage.
R&P is noisy and needs much more maintenance and protection from chips etc.
Ball-screws give a silky smooth action where has R&P is in comparison a clunky action so this does translate back into the cutter at some level.!!. . . For general wood working then this is fine and doesn't get noticed but if your wanting high quality finish or high detail then you will see a enough difference compared to ball-screw machine.
Again just My opinion and you choose to take my advise or not.? . . . . But let me just say go try to find some one who has experience of Both and ask which they would choose for a machine this size, weight and with your requirements.?? . . . . I know the answer because I've give it you.!!Last edited by JAZZCNC; 22-08-2013 at 08:10 PM.
22-08-2013 #3
OK,
I get it. I appreciate the help.
Then what would be your exact recommendation?
Drivers, breakout board, nema 23 motors , PSU combination in combination with which ball screws?
22-08-2013 #4
Ok for this size and with Gantry upto 70-80KG.
80V Digital drives and recommend Leadshine AM882
3Nm nema 23 motors like these SY60STH88-3008BF
70Vdc PSU preferably unregulated toroidal with correct amperage for all motors.
BOB recommendation is difficult because the one I'd recommend and think is by far the best is PMDX 126 but it's expensive. PMDX.COM - Products for CNC and motion control applications
The next I'd recommend and use often so know are OK boards is this one. OPPB but it's not in the same league has PMDX.
Ball-screws would be 10mm pitch and 16mm Dia for X & Y axis with 5m pitch 16mm dia. Motors would connect to them using 15mm HTD timing belts and pulleys with 1:1 ratio. This lessens resonance which helps on a steel framed machine and it's much more flexible if you ever want better resolution or higher speed has it's easy to apply a ratio with simple pulley change.
20mm Dia 10mm pitch could be used but really not required at this length and would be over kill, would also restrict performance not increase due to extra inertia of larger screw and ballnut.
All the above I've used on several steel framed machines with gantry's approaching 80Kg so know they work.!!
The Following 3 Users Say Thank You to JAZZCNC For This Useful Post:
22-08-2013 #5
I see that these get more popular here than the geckos. I read some threads here on the forum. I will go with them
I had my eye on these as a substitute for the ones that i had to buy from abroad and pay duty. I will look deeper in the specs, but most probably will order them through Zappautomation.
No idea for this one. I should educate my self how to calculate this amperage and from where to get the transformer.
I was looking into this one. For sure i need a board with 2 LPT connections as i need more ports for communicating with the VFD, turning on mist and vaccum and
On my actual small machine i have trip signals from the VFD and power detection which are very handy in real life. And a second BOb af course. So that BOB wins. Actually its not so expensive for what it offers. I spend more money on my 2 boards.
Sorry, i dont understand you
1. 1610 for long axis that moves gantry and 1605 for the gantry / that moves Z/ and 1605 for the z, correct?
2. I buy belts from Belting online. Should i use the minimum sized belt pulley or go a bit bigger for the size of belt i mean? What is the typical size? I cant seem to find the sheet i used for calculating belts. I remember the AT was stronger but a kind of harder. Obviously either way it should be pitch 5, otherwise i have to go with bigger pulleys
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
22-08-2013 #6
Will PM you about this has it's easy misunderstood and don't want others reading and not understanding properly so getting into trouble blowing stuff up and electrocuting them selfs.!!!!!
No 1610 for Long X Axis and Gantry Y Axis (moves Z).
Then 1605 for Z axis (UP/DOWN)
Don't go less than 18 teeth and I always use 20 teeth has the belt engages pulley better giving better wear.
Don't use less than 15mm wide belts and I find 15mm is perfect size. 20 or 25mm is overkill and wasted money.
HTD is the preferred belt type for it's profile but don't think it would make a big difference here anyway has the belts are only short and not under much stress or heavy loads.
Yes 5mm pitch.
23-08-2013 #7
After some fast brainstorm i decided on the CNC4PC breakoutboard 23 coupled with solid state relay board. This board seems more perfect for me:
1.I have my spindle control board from him and the support was great
2. All IC are mounted for easy removal without soldering / this is a big deal, i have repaired breakout boards in the past /
3. All necessary functions and really no extra ones that i dont need and would pay for choosing other boards
4. Better priced than the PMDX 126. When i started adding the spindle control/ not integrated/ ,relays, inputs, outputs, cables and so, the price jumped a lot
5. Some extra jumpers and functions i like
6. Straight out from the box 2 ports BOB with most possible inputs and outputs
Soon will start showing you packets
Thanks again to Dean/ JazzCNC/, now i know quite more than yesterday
Tomorrow will redraw the design for the ball screws.
Need help, buy or build to cut steel, stainless steel, titanium etc
By fatguyslim in forum Machine DiscussionReplies: 41Last Post: 08-02-2014, 11:37 PM -
A Sturdy Steel Framed Machine Design
By Boyan Silyavski in forum Machine Frames & BedsReplies: 0Last Post: 06-11-2013, 05:58 PM -
By Ricardoco in forum DIY Router Build LogsReplies: 6Last Post: 28-10-2012, 06:02 PM
