Thread: Wobblycogs CNC Mk2
Well I couldn't leave it alone :-)
One quick re-design of the z-axis stepper placement and I can't believe I didn't just go with this all along. Trying to save a few pounds on the z-axis I think was a false economy. This design has the ease of cabling of the previous but with lower z-axis weight as well. Double win, now I've just got to plug all the numbers for the z-axis parts into the spreadsheet again...
02-09-2013 #2
Great. .
. . . . Now put a proper bloody cover over the Z axis and give those bearings and screws a break. . .Lol
02-09-2013 #3
What width is your Z axis.? If you can make use of it I have a Z axis motor mount I made too narrow. It looks like pic below but with larger centre slot so 20T pulley goes thru. . . . It's 160mm wide and 19mm plate made for Nema 23/24 (60mm) motor.
Just cover postage and it's yours.
03-09-2013 #4
03-09-2013 #5LOL, I've got to leave myself something to regret not designing in from the start!Now put a proper bloody cover over the Z axis and give those bearings and screws a break.
That stepper motor mount would be really useful, thanks (my back plate is 190mm wide so it would fit perfectly). The stepper mounting plates are one of the bits I wasn't looking forward to making by hand.
03-09-2013 #6
Possibly this is a silly thought but is it worth trying to getting the X and Y axis ball screws machined so that they can be used with a fixed BK bearing on both ends? The price difference of the bearings doesn't seem to be much and it would increase the critical speed nicely. The only problem I can see is that I'd have to be quite accurate with the positioning of bearings.
Any recommendations on stepper motors? I'm currently thinking the 4Nm steppers from CNC4YOU look quite nice.
03-09-2013 #7
Not a silly thought and won't make it worse that's for sure but hardly worth the hassle has you'll have no problem with critical speed or whip at this length screw using steppers.
Regards the 4Nm then I've found the 3Nm motors spin faster and see very little to any difference in torque.!
10-09-2013 #8
I've been doing some reading about the electronics side of the project recently hence the lack of updates. I'm currently favouring a Mach based set up using an Ethernet SmoothStepper and the PMDX-126 board. A fairly expensive set up admittedly but one that I hope will be fairly trouble free. I admit I'm tempted to try out LinuxCNC first as I have a pile of old computers hanging around and a fair bit of experience with Linux (I run half a dozen Linux servers) but as an old friend once said to me "Linux is only free if your time is worth nothing" and I've found that to almost always be true.
My rails finally arrived from South Korea (48 hours to get from South Korea to Cardiff, 3 weeks nearly to get from Cardiff to Gloucester!). I got caught for import duty but not a lot so can't really grumble and they were still much cheaper than locally sourced stuff. I've given them a little slide about and everything seems fine. If I press down on the block it slides more easily, I'm guessing this is pre-loading? Is there anything in particular I should look for to check if they are ok?
11-09-2013 #9
I'm just about to press the button on the ballscrews and round rails so would be interested to hear where you got your linear rails from as I might bite the bullet, pay the extra, and get these from the outset. also I'm going to get a PDMX-126 BOB so give me a shout and I'll order one along with you and perhaps we can save some carriage by getting 2?
I keep meaning to have a play with Linux but I've been out of playing with PC's for years now so probably know enough to get me into trouble but not out of it!!
BUILD LOG: Wobblycogs CNC Mk1
By Wobblycogs in forum DIY Router Build LogsReplies: 91Last Post: 02-01-2013, 07:38 PM
