Thread: my router build - advice needed
02-12-2013 #8
This is very true regards alignment of profiled rails but there's more to it than that really in real world use.! And the Horse's for course's only applies to a point.??
The main problem with the Cheap round rail bearings, whether that be supported or unsupported is the quality. They are very poor and soon become sloppy and inaccurate when used in moderately harsh condition's, often needing regular or constant adjustment to keep good accuracy.
Now has you say horses for courses can apply and for DIY level routers they are Ok to a point but in the long run they are More trouble some and Far far less accurate then Profiled rails so if your wanting or looking long term and accurate then it's worth spending the Money and slight extra care that's needed to use Profiled rails.
For Machines like Plasma you'd say Unsupported are fine because there's no Cutting forces involved but Again Plasma can give off very Harsh dust that will Kill the Cheap Bearings in short order so it would be false Economy and more hassle in the long term.!!
IMO and experience the Round rail are just not worth the Hassle and for just a Few dollars more profiled rail turns mediocre machines into Proper machines. This is also reflected in the Re-sale value.! They add far more Value than the sum of there parts and make the machine that much more appealing and sell-able.!!
Advice on Mammoth CNC Router Build - Steel Framed - 2440mm x 1220mm cutting area!
By Wejjmeister in forum Gantry/Router Machines & BuildingReplies: 87Last Post: 03-01-2016, 12:45 AM -
BUILD LOG: New cnc router build looming, advice needed
By Mad Professor in forum DIY Router Build LogsReplies: 5Last Post: 06-11-2012, 08:12 PM -
Advice needed for Z Design
By Hobgoblin in forum Linear & Rotary MotionReplies: 8Last Post: 10-09-2012, 09:18 PM -
Much advice needed for an 8' x 4' cnc router project / and vacuum table
By FlightCaseCo in forum General DiscussionReplies: 1Last Post: 01-01-2012, 12:34 AM -
new mashine build advice needed
By Finrod in forum Milling Machines, Builds & ConversionsReplies: 2Last Post: 14-10-2008, 11:05 PM
