    Hi
    that sounds a good price for a machine that size, i had been bidding on similar in the UK. Do you know how heavy it is.
    When your moving it, make sure it does not bend under its own weight in the middle, Also, depending on its weight, you may need some machine skates. Good luck with moving it but make sure you understand the weight. And look for purpose build lifting points/connections.
  2. The Following User Says Thank You to george uk For This Useful Post:
  3. Quote Originally Posted by george uk View Post
    Hi
    Well, my idea is to join 3 pallets with 6 x 3m long wood beams, in order to make a 3m x 1,5m pallet, with fixing/anchoring points.
    Then with the help of a hi-lift, slowly put the CnC over the pallet. Fix the CnC router to the pallet and wrap it with plastic film. Then with the help two pallet lifters, pull the pallet near to the trailer:
ID:	12026 Click image for larger version.
ID:	12027 that as 3220x1760mm and can carry 2900kg.
    The with the help of an electric winch assembled in the trailer, i will pull the pallet to the trailer helping with pallet lifters.
    Off course Ideally i would have some machine skates (squid table) to roll the pallet into the trailer. Better, would be to have a Fork Lift Truck to place the pallet with the cnc on top of the trailer...
    What do you think?
  1. BUILD LOG: my router build - advice needed
    By thomashomer1986 in forum DIY Router Build Logs
    Last Post: 02-12-2013, 11:45 PM
  2. Chinese 6040 CNC Router Advise Needed
    By Bob Hepple in forum Chinese Machines
    Last Post: 27-11-2013, 12:00 PM
  3. RFQ: laser or router cnc needed
    By ktc in forum Projects, Jobs & Requests
    Last Post: 09-08-2013, 12:08 AM
  4. RFQ: help needed to make cnc machine maybe 2-3 and will pay
    By scnc in forum Projects, Jobs & Requests
    Last Post: 22-11-2012, 12:31 AM
  5. BUILD LOG: New cnc router build looming, advice needed
    By Mad Professor in forum DIY Router Build Logs
    Last Post: 06-11-2012, 08:12 PM
